New thunderbolt interface
Looks like Motu has made a thunderbolt version of the 828:
http://www.motu.com/products/motuaudio/828x So far, this is the cheapest thunderbolt interface I'm aware of. Other than the thunderbolt connection, it appears to be identical to the 5+ year old 828mk3, so it probably doesn't sound as good as the other thunderbolt interfaces currently available, but it's still a lot of bang for the buck when you consider how many IO it has. I'm curious to see if it has improved latency when compared to it's predecessor (could not find specs on the site).
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Re: New thunderbolt interface
Useless unless your machine has two T-bolt ports. What would possess a company to NOT put a second T-bolt port for daisy chaining? If you want to run another monitor, or T-bolt drives you'd be hooped.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Because it's not true thunderbolt. All it is, is a built in thunderbolt to FW cable inside the box. It's still FireWire regardless of cable used.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
Meh lol PCI-SIG is already working on releasing a new small factor PCI format that will offer 32Gb/s through 4 pcie lanes and it is also optical and copper.
PCIe OCuLink Since thunderbolt is so slow to adopt and that PCIe is far from being dead as some predicted, I'm sure we're going to see a far greater adoption of the PCie OCulink. |
--- The single Thunderbolt port on the Avid HD Navive box was an even more frustrating decision. Bad mistake Avid. |
The real increase in PCIe usage happening now is likely with PCIe direct attache flash storage, and that is likely to continue in further with adoption of things like NVMe SSDs. One of the issues I have with the new Mac Pro, is with all the PCie bandwidth wasted on GPUs and Thunderbolt you can't get at the PCIe 3.0 lanes directly to use them on things like NVMe. |
I must have filtered out their nonsense in real time
Motu thunderbolt interface (828x) | Marcel Risberg | General Discussion | 1 | 03-17-2015 08:27 AM |
Thunderbolt Interface | chann48211 | Getting Started | 12 | 05-27-2014 07:46 AM |
So what about new ThunderBolt interface and VENUE? | digidesigner | VENUE Live Sound Systems | 6 | 02-18-2013 09:46 AM |
HD native thunderbolt - without Interface | ilulilu888 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-26-2012 10:31 AM |
HD Native Thunderbolt Interface | M-ManLA | General Discussion | 16 | 09-10-2012 08:11 PM |
