Old 09-13-2016, 05:47 AM
White Fire Sky White Fire Sky is offline
Default Re: Distortion Sound on Pro Tools 12?
I just wanted to let you know that this definitely worked. When the noise appears I change the buffer size - any direction - and it goes away.
I can't believe it is fixable so quickly - it pained me for months!
Thanks so much for sharing your knowledge. It is much appreciated!
Victoria
Old 09-15-2016, 04:26 AM
810 810 is offline
Victoria
I have been having a distortion problem that occurs only sometimes. I plan to try your solution. I had been thinking it was happening cuz I have been recording at 192 kHz and had never used that before getting P T 12 a month ago.
My solution has been to patch record the distorted spots (it happened spottily through a seven minute song) and I had primarily blamed/changed poorly planned automation on pitch shift and reverb plugins.
When I patch recorded the stretches with distortion I had to record and undo several times before I got a take with no distortion. The clear sound of the Drums made it obvious when I had a good take. At which point I had to drag the ends to some good overlap and finally when all patches were done, consolidate.
This was effective but time imperfect.
Sent from my HTC One using Tapatalk
Old 01-21-2021, 09:33 PM
BusyBoxSt7 BusyBoxSt7 is offline
Did anyone ever find a permanent solution to this or do we have to keep opening/closing the playback engine settings? On PT 2019.12. Is it possibly related to a certain brand of converters or.. ?
If this hasn't been resolved, Avid should just add a "fix" button to the mix and edit screens so it's faster to clear the garbage sound.
Busy B
Sound Distortion Issues with Pro Tools 8 SupposedGhosts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 09-08-2013 03:27 PM
cant get any distortion to sound good alaskan eel Eleven Rack 18 09-04-2013 10:05 PM
Sound Distortion/Buzzing In Pro Tools SE? StereoProphet Pro Tools SE and Essential (Win) 1 06-16-2013 03:27 PM
Distortion sound from PT and Focusrite 24 Andy1138 macOS 5 09-20-2011 02:04 PM
Sound distortion with Pro tools LE 7.1 melodic101 Pro Tools TDM Systems (Mac) 0 03-16-2007 11:38 AM
