Old 01-21-2021, 04:15 AM
Cayce Cayce is offline
Default Input Channels Stuck in Pre-Fader Metering
I just upgraded to PT 2020.11.0 and my input channels are now stuck in pre-fader mode. The meter reads the same whether Pre-Fader Metering is checked or not, with the slider all the way down. Post-fader should show nothing at that setting. The signal drops out with the slider down, as it should, but the meter still reads as if in pre-fader mode.
Is this a bug, and is there a remedy?
Thanks.
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
2TB Internal Fusion Drive
2 4TB External Drives with Mirrored Backups
2 External Monitors: 27" & 65"
Old 01-21-2021, 04:25 AM
Default Re: Input Channels Stuck in Pre-Fader Metering
Never heard of this, can anyone reproduce? Lucky you are stuck on pre-fader as that is the more useful mode of the two.
Old 01-21-2021, 01:51 PM
Personally, I stay in pre-fade metering for 99.5% of my work. The only reason I ever use post-fade is to quickly balance a bunch of similar tracks(like a dozen violin tracks and a bunch of BG vocals). And, as soon as those tracks are balanced, I switch right back to pre-fade(post-fade is simply not a good way to record or mix). Having said that, the meter still should work as you describe(and it does work that way on my rig running the most recent release), so I would look at a few things:
1-IO settings>Output tab, check the Monitor Path, Audition Path and AFL/PFL Path(they should match your main outputs)
2-Options menu>make sure Pre-Fade Metering is UNchecked
And there is always trashing prefs(worth a try for any "odd" behavior).
If you're wondering why I stick with Pre-fade metering(a fair question), its because I want to know what's going on with the levels within any given track(with post metering, turning the track fader down can mask clipping). Plus, its very possible for 2 tracks to show the same meter level, but not be balanced at all due to frequency content or plugin processing(so try to use your ears more and your eyes less)
Old 01-21-2021, 07:32 PM
Thanks.
There are no other people complaining about this on DUC so it will very likely be something you are doing wrong or a local messed up system.
What type of track is it?
Not sure I can think how it could be this but have record/playback faders uncoupled?
As always start by trashing prefs.
This happen on multiple sessions?
Pre-Fader vs Post-Fader Metering jphaudio Tips & Tricks 2 12-05-2020 11:35 AM
First Fader of Artist Mix is stuck to whatever Dock fader is mrtomcat Artist Series 10 08-23-2019 02:51 AM
Changing 2mix metering channels on Control 24? pearldrum944 ICON & C|24 0 12-21-2010 01:47 AM
Input monitoring and pre fader metering PROCHIC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-27-2010 05:52 PM
Pre-Fader Metering vs Post-Fader Metering teacherman Pro Tools TDM Systems (Mac) 3 01-29-2008 08:33 PM
