Old 06-29-2020, 05:52 PM
stephendanielson97 stephendanielson97 is offline
Default Re: Keyboard wont make sound in MIDI-USB
The midi studio set up portion of the video is where my issue diverges, just to specify
Old 06-29-2020, 07:51 PM
Southsidemusic's Avatar
Need to know what 2020 version and what exact OS version?
First make sure the USB cable is working and try another USB port.
Make sure the USB port is not in any kind of ”performance mode” and tuned off or gone to sleep for power saving.
Also do you record arm the VI track and still no meters working?
You are using a Instrument Track?
Do you have LOCAL OFF on the Yamaha MO6 or MO8 keyboard in MIDI Setting from the Keyboard?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-29-2020, 08:39 PM
Ben Jenssen's Avatar
Originally Posted by stephendanielson97 View Post
- Making sure the MIDI Thru box is checked in Options
- Making sure my device is recognized in Input Device Drivers and that all the boxes are checked
- Making sure the Track Enable button is on on my Instrument Track
- Making sure my Device Driver is recognized in my Device Manager on my computer
- Using MIDIOX to detect the signal of my keyboard (it does)
- Making sure my keyboard is on lol
- Making sure MIDI editor is working on its own
- Making sure my playback engine is set up correctly
- Making sure i can still record in audio by plugging my piano into my interface
And track rec enable button?
Old 06-29-2020, 11:23 PM
A lot of people seem to be having issues with their keyboards not making sound when they are being recognized as [Emulated], it could just be a problem with the DAW. If it is then I have no idea why it hasn't been fixed yet, since posts from 2014 seem to be expressing the same frustrations as I am. Like I said, Pro Tools First was working fine while I was using it, once I upgraded though everything failed. If anyone has a current answer for this, it would be greatly appreciated.
Old 06-29-2020, 11:49 PM
Figured it out! You have to right click on the Pro Tools app, select Properties, go to Compatibility, select Run this program in compatibility mode for Windows 8 (I also selected the "Run this program as an administrator" box in Compatibility) and THEN run the program (I right clicked and selected "Run as Administrator just to make sure because I don't trust anything anymore). This was an incredibly stupid problem that took days to solve, I sincerely hope that Pro Tools patches this error since it seems to have been an issue for a while now. Hope this helps anyone as confused as I was!
Make Midi keyboard horizontal instead of vertical? GOOOTOOO General Discussion 5 01-13-2020 04:18 PM
I got my mic to work, but now my MIDI controller doesn't make a sound snakeman5001 Getting Started 9 10-26-2019 09:25 AM
Making Imported MIDI Tracks Make Sound Trouble_Clef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-31-2010 07:12 AM
BUG?: Tracks that wont make sound anymore Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-05-2006 11:46 PM
How can I make Pro Tools LE recognize my midi keyboard? Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-26-2003 12:10 AM
