  #211
Old 09-06-2019, 03:25 AM
henningaround henningaround is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
I guess it could work this way:
Code:
-- Define Insert to open here
set Insert_to_open to "Insert Assignment A"
tell application "System Events"
	tell process "Pro Tools"
		set frontmost to true
		-- Define the correct Insert group. Maybe there is a more elgant way?
		if (Insert_to_open = "Insert Assignment A") then
			set Insert_group to "Inserts A-E"
		else if (Insert_to_open = "Insert Assignment A") then
		end if
		tell (1st window whose title contains "Edit: ")
			set selectedTrack to title of button of UI element 2 of (1st row of table "Track List" whose selected is true)
			set formattedString to text of selectedTrack as string
			set AppleScript's text item delimiters to "Selected. "
			set theTextItems to every text item of formattedString
			set AppleScript's text item delimiters to ""
			set formattedString to theTextItems as string
			display dialog Insert_to_open
			click button Insert_to_open of group Insert_group of group formattedString
		end tell
	end tell
end tell
The way to get the selected track into the script was posted here before :) You should be able to use this in a similar way for Solo, Mute, etc.
  #212
Old 09-06-2019, 03:31 AM
OH please kill the line:
Code:
That was just a help while coding
  #213
Old 09-06-2019, 04:17 AM
TrentWilliams TrentWilliams is offline
Code:
Wow, this works .. !!
Amazing, thank you sooooo much. I really, really appreciate this.
I can interchange this script for Inserts/Sends, so this helps a lot.
Is there anyway to speed up the script? At the minute its taking a second or two to open the windows.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
  #214
Old 09-06-2019, 04:42 AM
I don't know, I'm really not an Applescript Pro... I think it's been mentioned here, that this is just the way applescript works. Maybe the guys at SoundFlow know a better way ;-)
  #215
Old 09-06-2019, 05:04 AM
Thanks anyway,
This is truly amazing.
I wonder how it would work in javascript?
  #216
Old 09-08-2019, 10:00 AM
Oliver M Oliver M is offline
Code:
		end if
		end tell
	end tell
end tell
Great stuff Henning. Just keep in mind that the script will fail if no track is selected. So an on error check is needed. 😉
  #217
Old 09-08-2019, 11:13 AM
Yeah, you're right. That's were one can see that I don't write the code myself but copy and paste stuff together and modify it until it works
  #218
Old 09-09-2019, 05:38 AM
There's nothing wrong with that. 😉
Here's a cleaned up version with error checking.
Code:
if ptIsRunning() then
			end if
				try
				on error e number n
					if the n is -1719 then
						tell application "Pro Tools" to display alert "No track was selected." message " " buttons {"Cancel"} default button 1
						return
					else
						tell application "Pro Tools" to display alert "An Error Occurred" message e & " (" & n & ")" buttons {"Cancel"} default button 1
					end if
				end try
				if exists (button Insert_to_open of group Insert_group of group formattedString) then
				else
					return
				end if
			end tell
		end tell
	end tell
end if
on ptIsRunning()
	return application "Pro Tools" is running
end ptIsRunning
  #219
Old 09-11-2019, 12:08 AM
Oh thanks a lot. I have to implement that. Scripts get longer and longer...! Are you just using AppleScripts directly mapped to a keystroke? I'm using a combination of Keyboard Maestro and AppleScript right now. In Keyboard Maestro I specify variable or ask for Input (e.g. an AudioSuite Plug-In or an Insert to open) and give it to an Applescript to perform the action.
  #220
Old 09-11-2019, 02:31 AM
Most of the time I use AppleScript Bundles triggered by FastScripts via keyboard shortcuts but of course you can use any combination that works for you.
Sometimes I compile AppleScripts as apps, where it makes sense.
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
