Disable (not uninstall) plugins?
I do not have time to check the forum if this has already been answered.
But is there a way to disable PT's plugins, such as the AIR Multidelay, Chorus, Reverb, and so forth? Thanks. |
Re: Disable (not uninstall) plugins?
Try holding shift when you launch Pro Tools.
i would drag them from your plugin folder...over to the unused folder......if you don't want them showing up in the list.....
But don't you have to trash the pref's after you do that to update the list????
What do you mean, you have to trash the preference?
I'll try that too. Thanks.
Um you should search the DUC - for trashing the pref's it also should be on the - help us help u page - which should be a thread at the top of this sub forum
How to disable plugins in PT11 | Joe.LoDuca | Windows | 3 | 01-22-2014 08:58 AM |
IE 8 how uninstall or disable it in WINDOWS 7 help | flautista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-18-2009 06:42 PM |
plugins disable on record??? | Crank1000 | Pro Tools TDM Systems (Mac) | 60 | 09-28-2009 11:24 AM |
Is it possible to disable plugins? | juliussantua | Pro Tools TDM Systems (Win) | 4 | 02-16-2007 10:02 AM |
Temporarily disable some of my plugins from loading? | GuitarEasley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-20-2003 09:57 AM |
