#141
Re: "Some regions had invalid bounds and were adjusted or deleted"
I know Digi have found a specific problem with undo queues but at exactly the same time this bug emerged, I've had other things happen that are triggering the "Some regions had invalid bounds" dialog when I reopen a session. I NEVER had this prior to 8.0.4 I'm getting valid regions becoming corrupt in some way and then being removed from the session by the "Some regions had invalid bounds" dialog when I reopen. They are still on disk but any reference to them in the session, both in the region list and edit window is getting lost. Regions are going missing from my session in other words. So OK, I've not had missing files but regions disappearing from the session is NOT good. The other day I was editing the start of a region and bang, it greyed out and jumped to italics in the region list. When I reopened the session, the "Some regions had invalid bounds" dialog deleted any reference to it in the session. Watch it happen here: http://www.youtube.com/watch?v=K6ML1EFmevs Prior to the region start edit in the video, the region played back just fine. I have NO idea if this is related to undo queues but to me it's an issue nonetheless!
Dave Marsden UK |
#142
Hey Dave, yah your situation is for sure a troubling one. The fact that it's onset coincides with the start of your using 8.0.4 is worth noting but, as Avid Tech has noted, there is still no indication that any of these problems are related to the missing regions dialog. Obviuosly, that doesn't make your issue suck any less. I've been using 8.0.4 since it came out and have had the missing regions message but have no other issues whatsoever. I'm running big sessions with lots of audio and some VI's.
#143
Werner
I'm sure you're probably right that it's just coincidence.
Dave Marsden UK |
#144
The only 8.04 system I've been using is my LE system. This "error" happens quite often on that system too ........ it didn't happen in 8.03 (cs2 I believe was my last version). To this point I haven't noticed any missing active/playlist regions.
#145
Seeing it on many sessions now. Just opened a session, but my previous edits from last visit were missing. All the correct audio was in the audio files including a piece of tuned audio from within the edit. Session save time was after the audio record times.
#146
Should have said...OS 10.6.4 and PT 8.0.4
#147
I am having it on just about every session. Very embarrassing with clients there. Hey what is that all about? Oh nothing the software is acting up but the audio seems fine. Seems fine. Hmmm. Trust goes down a bit. Not ideal in working situation. Digi any word on this? Need a fix fast.
#148
Have also had a few where it loses the audio for small snippets in the session. I have to pull it in from another session and re edit the [bleep][bleep][bleep][bleep] I spent hours getting in shape. Just sucks really. Need to fix now. Pretty bad feeling not knowing if the session is going to open like the last time you saved it. Feels cheap and a bit thin.
#149
http://felixrost.de |
#150
The audio within the edit was still on the drive but the new edit regions in the session had gone.
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? | meech | Pro Tools TDM Systems (Mac) | 22 | 06-21-2014 12:47 AM |
"Out of Bounds" / "Invalid bounds" bug still exists! | 12StringJ | Pro Tools 10 | 1 | 07-21-2013 12:34 PM |
Some Clips Had Invalid Bounds and Were Adjusted or Deleted Bug! | Siegfried Meier | macOS | 2 | 01-28-2013 07:32 AM |
pt8 won't open session (some regions had invalid bounds and were adjusted or deleted) | terryrocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-26-2011 11:02 AM |
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! | acmost | Pro Tools 9 | 0 | 11-13-2010 05:40 AM |
