Old 03-02-2002, 09:04 PM
DaveCarlock DaveCarlock is offline
Default Checking System usage--"dead DSP". Normal?
Checking System usage--d24 (2nd card after MIX Farm) says "dead DSP", and the meter is fully red. Is this normal? Anyone seen this?
Old 03-03-2002, 06:15 AM
Zeus Zeus is offline
Default Re: Checking System usage--"dead DSP". Normal?
Yeah, I've seen it. And not a funny situation : the card was broken. [img]images/icons/frown.gif[/img]
Z
Old 03-03-2002, 09:19 AM
Digi, this card has just had it's chips upgraded by tech support for use in a Bit 3 chassis. Can you jump in with some comments?
Old 03-04-2002, 10:10 AM
DigiTechSupt's Avatar
As Zeus suggested, this usually indicates a hardware failure.
In one case regarding the 'Dead DSP' message on a d24 card, the problem would only present itself after the card was running for some time, which might be specific to your situation as well. Please contact tech support via phone to discuss repair options.
Brent
Avid Audio Tech Support
Support FAQ
Old 03-08-2002, 06:20 PM
Snitz Snitz is offline
If you haven't tried reseating your MIX cards, you should give that a try. Had this error two or three times on my mobiles rig, reseating did the trick.
andy
10.1.1 not showing "disk cache" under system usage [solved] Silky Pro Tools TDM Systems (Mac) 1 03-27-2012 12:21 PM
Difference between "system" and "CPU" usage? ashdot Pro Tools TDM Systems (Mac) 1 05-01-2003 02:01 PM
Difference between "system" and "CPU" usage? ashdot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2003 01:51 PM
AMIII showing in "System Usage" window SimonThornton Pro Tools TDM Systems (Mac) 2 11-19-2001 11:18 AM
AMIII showing in "System Usage" window SimonThornton Pro Tools TDM Systems (Mac) 0 11-13-2001 03:43 PM
