Adding Effects to a Track
Hey guys,
As you will tell from my extreeme newb question, I am very new to Protools. I have only had it for 24 hours and I have next to no experience with any recording programs other than cooledit pro. My buddy told me when I am applying effects, I want to start them in a new track, then route the track through the proper "bus". Well I totally forget what he showed me. can somone please tell me step by step how to route the busses properly? Thanks |
Re: Adding Effects to a Track
Route(output)your track's to a bus.......let's say bus 1&2.Create an aux track and select the input as bus 1&2.Apply the fx you want for the bussed tracks to the aux track.Name the aux track.......usually you name it the fx you inserted on it.Bam......your done.
Bug ridden Pro Tools 8 but back to 7.4 HD2,192 I/O,96 I/O,Midi I/O,Control 24 |
Thanks man, I actually was doing it backwards lol
I can't believe I didn't figure it out, but thanks. Second question: I realized that I can take the effects off if I directly add them to the track. So why would I want to make a separate track in the first place? I thought the reason for it would be so you would still have that raw track to go back to. Is there another reason why we want to add effects to a separate track? |
routing effects to an "aux bus" serves two purposes:
1. conserve cpu resources (especially if you are using a reverb type effect - you don't want this over multiple tracks). 2. simplify setup (not having to remember / setup each individual track's plugin settings). 3. provide sophisticated routing (use of pre / post on an aux to send the signal to somewhere else). most people are concerned with #1 & #2.
http://www.myspace.com/blaqmusicgroup |
Adding Effects | mike1234 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2008 01:01 PM |
Adding Effects to a selected Part of a Track | lmoore | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 05-17-2006 02:28 PM |
Adding effects to Midi tracks | ScottFB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-15-2006 07:39 AM |
Adding effects during a bounce | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-20-2005 10:02 AM |
adding external effects | arcarsenal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-21-2003 02:42 PM |
