Old 02-02-2007, 02:52 AM
owen247 owen247 is offline
Default Intel mac update Sampletank 2.1 Issue - instrument
HI
I have just bought a new iMac (2.33 core duo 2, 2 gigs RAM) and am in the process of setting it up with pro tools etc. so fa r everything is gouing fine and other plugins are working. But I have an issue with Sampletank 2. I installed it and can see it in pro tools when I go to insert it on an instrument track, but when it pos up I cant see any instruments in it. I copied all of the instruments in from the original ignition pack cd to the corect location
Applicatios/IK Multimedia/Sampletank 2 SE/ST2SEInstruments
I have tried re installing it numerous times.
One error I made initially was to installl the intel update version Before installing the older version on CD. but I unistalled and started the process from scratch... can anyone help.
basically how do I get Sampletank 2 SE to see the instruments in the folder??
Thanks
Old 02-02-2007, 07:01 AM
OddsAre OddsAre is offline
Default Re: Intel mac update Sampletank 2.1 Issue - instrument
if you open SampleTank as a plugin then head to the right side and click on PREFS, a window will appear, you'll see the root folder can be changed there. CLick on browse and find the Sample Tank folder where your patches are stored. That should solve it. If not, try saving all the patched to an external drive. Than of course change your root folder in the prefs again to match. I keep mine on an external 250GB drive and only plug it in when I use Sample Tank. Hope this helps.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Old 02-02-2007, 11:22 AM
thanks so much for that...
it seems so obvious now but somehow or other I didn't click that button before....
1 other quick question, does anyone know how to resolve an issue with the IK Multimedia product registration continually popping up even though I've authorized this product successfully several times... every time I restart pro tolls sample tank looks for the serial number again... very frustrating...
even if this has been dicused before and someone knows where can you post a link... I cant seem to find it
Old 02-02-2007, 11:59 AM
OK, I figured out the issue with sampletank forgettin the authorization information....
you have to find the file ST2SEPref.txt which was in Mac HD/Library/Application/Support/IK Multimedia/SampleTank 2.x SE/Prefernces
I opened it in a text editor and there was very little in it, something like
firstlaunch=no
so I deleted this and entered my serial no and auth code like this
RegID=XXXXXXXXX-XXXXX-XXXX-XXXX-XXXX
Serial=STS20-XXXXXXX-XXXX
(obviously I'd never give away my real auth details)
saved it, restarted protools... and it's benn fine ever since....
Old 10-26-2007, 07:09 PM
ddwolff ddwolff is offline
I am still having the same problem, even having the correct Root for the Samples!! What gives!
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue ZDF macOS 0 01-14-2013 02:47 PM
update Live, Reason/Sampletank adapted 4 intel mac krusheasy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-05-2006 02:24 PM
Sampletank SE for intel mac? qpeck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-10-2006 12:00 PM
SampleTank SE and BFD Plugins Not in Instrument Li Dondusko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-21-2006 07:32 AM
assigning SampleTank instrument question Jervy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 05-24-2003 08:01 AM
