Audition Path in PT7
I'm wondering why since 6.9 Digi has cut the option for setting the audition path trougth digital outs in the 002R. Since I use an external converter connected to the ADAT port of the 002R I'm not able to hear any files and any preview in PT.
I hope this has been fixed in PT7. Please, can anyone of you who have already installed PT7 check it? Thank you.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Re: Audition Path in PT7
need this to work to !!!
please info on this issue |
no, they didn´t fix it. it seems to be many, many months since so many of us have asked for that. no spdif and adat audition paths here on pt le 7. lets keep on waiting...
but i wonder if there is any sense behind that. maybe the truth is simply that they have no manpower or time to rewrite the codes. i don´t know.
digi 002 rack MacPro 2 x 2.66 GHz Dual-Core intel Xeon 5 GB RAM OS 10.4.10/PT LE 7.1.1cs2 |
Hey, Digi why don't you fix this?
Is this a way to force us to buy an HD? I'm not sure, but from what I remember, audition path through digital worked on 6.7. If this is a bug please fix it, if this is a your commercial choice I think is a bad one. I think folks around there want to have more when updating, not less.
I've had a few versions of ptle and ive never seen an option to audition through digital outs?!! Is definately something that would be cool but I dont think it can work because the Core Audio driver is already in use for Pro Tools. It's like the fact you cant have Itunes coming through your digital outs while pro tools is using them i guess.
But in LE you can use all analog and digital ports simultaneously. Therefore it sounds that the Digi Core Audio manage analog and digital ports. But if Digi would like to say something about that it would be appreciated.
It did work on 6.7 and I not exactly sure why they took it away. The response I got from DIGI is that they are aware and going to fix the problem. Why it is not fixed on version 7 I have no idea. I got this response when 6.9 was first released, they have had plenty of time to fix!!
www.klearlightstudio.com |
Thought I would BUMP this. Kind of a pain working without SPDIF audition. Worked fine (mirrored with analogue inputs) with my Digi001. 2 steps forward, 1 step back!
"you need to have a valid audition path in I/O setups to audition" - HELP ! | Riquier | Pro Tools M-Powered (Mac) | 5 | 04-29-2014 02:34 PM |
Audition Path | jamiecer | Pro Tools TDM Systems (Mac) | 2 | 06-16-2008 09:14 PM |
Audition Path Limitations | zakco | Pro Tools TDM Systems (Mac) | 2 | 07-28-2007 11:34 PM |
Audition Path | Felix Rost | Pro Tools TDM Systems (Mac) | 0 | 03-14-2007 05:53 AM |
Audition path | miha78 | Pro Tools TDM Systems (Mac) | 0 | 06-06-2006 01:20 AM |
