Old 10-06-2007, 02:42 PM
cubasteve cubasteve is offline
Default Auto Match Indicator
What happened to the little triangle lights on each channel by the faders that told you which way to move the fader to get back to where it was before you grabbed it?
Are they now the Auto Match Indicator which indicate something else? Is this a preference? Is the old way gone? I miss that feature...
Let's say i want to bump the vocal a bit but then decide i don't like it and want to slide the fader back where it was. How do i do that now?
Steve
Old 10-06-2007, 09:16 PM
Fireball71 Fireball71 is offline
Default Re: Auto Match Indicator
CTRL + Z
Undo
Music Is Life
Old 10-07-2007, 09:44 PM
CTRL + Z
Undo
Yes, i'm hip.
But i liked knowing where i was in relation to where i started while dragging the fader up and down trying to find a good level. Is that feature no more? Did it have a name?
Cubasteve
Old 10-08-2007, 10:55 AM
The Weed's Avatar
The Weed The Weed is offline
In the Mix Window the AutoMatch triangles are under the Voice Selector in each channel strip. How you can get them to work in LE, I'm not sure. From what I can gather from the manual, that feature is HD only.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
What does the clip indicator actually mean? davegibbon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 24 11-11-2009 09:04 PM
Auto Match Pull Factors & 25fps to 24fps workflow tj_davies Post - Surround - Video 4 03-05-2008 09:26 AM
Delay Indicator in Pt LE ? Red*Ketchup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-17-2005 05:42 PM
Peak indicator d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2003 03:38 PM
"Auto Match Pull Factors" lancebrwn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2003 10:37 AM
