Repeated AAE 6101 Errors in PT11 w/ Mavericks
After searching the boards for a few days I haven't been able to find a similar post with a solution that worked for me so I would really appreciate any input.
After the announcement of Mavericks compatibility for PT11, I went ahead and updated my OS. Unfortunately, after a few minutes of use in any session (with/without plugs and regardless of number of tracks) I begin getting CPU overload error messages (regardless of buffer size). System usage only shows me using approx 12% of my total CPU. I've installed Waves Gold Bundle, BFD3, and most recent UA plugs and drivers. Not sure where else to go. I remember when I had this problem on PT9 I selected 1 processor (instead of 2) in the preferences and it solved the issue. That option doesn't seem available in PT11 though. I missed the fact that PT 10.3.8 couldn't be clean uninstalled in Mavericks. Could this be the cause? If so, how do I do a manual clean uninstall? Thanks so much for any help! Last edited by kelcywhite; 12-16-2013 at 04:17 PM. Reason: Needed to include additional information |
Re: Repeated AAE 6101 Errors in PT11 w/ Mavericks
I feel your pain kelcywhite, thanks for posting. I'm having the same issues and increasing buffer size has absolutely no effect. I've attached a screenshot of what I keep seeing, regardless of the amount of tracks/plugins. I only have one plugin going on this particular session but that doesn't seem to matter. I had the problem pop in when I was even just setting up my click track. Hoping someone will respond to this with some answers. My system info is below:
OS X Mavericks 10.9.1 Pro Tools 11.1.0 Apogee Duet 2 with OS X 10.9 supported software installed Apogee Maestro 2.8.8 Last edited by wiggity5050; 12-31-2013 at 12:40 AM. Reason: Attachment not visible |
Both of you please list your whole system -- Computer + interface
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
I have a brand new iMac
OS X 10.9.1 Processor: 3.5 GHz Intel Core i7 Memory: 8 GB 16003 MHz DDR Interface: Apogee Duet 2 USB Pro Tools 11.1.0 |
Apogee Duet 2 has serious issues with USB on the new imacs. Best solution I have heard working is adding a Belkin Thunderbolt Dock and running from there. Many have also reported issues with Fusion drives in these setups - either just SSD or Spinning drive reccomended (though possibly you cn split your fusion drive).
Long thread on Gearsluz about this with Apogee folk weighing in. From post 269 on is the main points... http://www.gearslutz.com/board/music...w-imacs-9.html
Yeap Im getting the dreaded AAE 6101 Error after installing Pro tools 11.2
New iMac 16GB ram Mavericks 10.9.2 1TB fusion drive. what to do! |
Mbox 2 Pro Thunderbolt
check my post, right before yours
go back to 11.0.2 and the 6101s will go away, for sure |
Hey there, I won't go back just yet,
I've just disabled the video engine and deselected 'minimise additional I/O latency' and I've no errors with five mins of recording... hmmm ill keep testing and see ) |
iMacs with the Apple Fusion Drive are BAD news!!!!
this has been extensively covered on this forum. Check this out: http://duc.avid.com/showthread.php?t=347495&page=6 |
Committing to PT11 and Mavericks | propower | macOS | 1 | 02-25-2014 02:10 PM |
Is Mavericks now the preferred OS for PT11?? | propower | macOS | 3 | 02-15-2014 12:46 AM |
CPU Overload -6101 : PT 11.1.2 Mavericks | philipz794 | Pro Tools 11 | 8 | 02-12-2014 12:02 AM |
My Mavericks PT11 exp. | mactools | Pro Tools 11 | 0 | 10-22-2013 08:56 PM |
