Locating the time location of a region in its parent?
Hi folks-
I made a stupid mistake in my editing, and now I have a whole track that contains lots of regions from the wrong playlists. For many regions, I can just flip through and find the correct playlist visually, but only if the audio was not moved from its spot in the original timeline. Unfortunately a handful of regions were moved in the timeline, so it becomes difficult. I can tell which playlist the incorrect region came from, and which playlist the correct region should have come from, but I can't find the exact time location that it came from in its original playlist/parent audio. If anyone has any helpful tips on that I would be most grateful. thanks |
Re: Locating the time location of a region in its parent?
I probably do not know your exact problem, but can´t you :
in the playlist, where the incorrect clip came from - check each clip with spot mode that the actual start is the same as the original time stamp, and if not : correct it back to the original time stamp ? (The moving in the timeline, was that done with the clip still in the playlist or after copying/moving it to the track that contains lots of regions from the wrong playlist ?)
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
lock midi region to sample location | blastula | macOS | 2 | 02-11-2014 02:59 PM |
Copied region length auto-adjust to paste location length? | greglawrence | Tips & Tricks | 4 | 10-23-2011 12:46 PM |
Linking region with Memory Location | Graham wilde | Tips & Tricks | 4 | 11-25-2010 04:12 PM |
Parent region no longer appear in Edit Window | milestone | Pro Tools M-Powered (Mac) | 0 | 03-15-2010 11:30 AM |
How do i insert a region on the cursor location !! | vudoo | Pro Tools TDM Systems (Mac) | 1 | 01-02-2005 03:06 PM |
