Eleven Rack and V-drums
Has anyone recorded playing guitar through the eleven rack and v-drums at the same time via the midi port? I'm considering picking one of these up as an additional interface but the usb concerns me (I have a 002R currently) and I'm not sure if the latency will be a problem. Thanks.
Re: Eleven Rack and V-drums
What do you mean by
If that is what you mean, then yes you can do that. I do something similar. I use a real drum kit that has Ddrum Pro Triggers on the drums, which connect to an Alesis Trigger I/O which I plug in to either the 003R's MIDI IN port or use the USB - MIDI out of the Trigger I/O. I place Strike or Superior Drummer on an Instrument track, and the real drums trigger the drums in Strike, plus I can mic the kit as well. This works great for jamming and when recording together, i give everyone headphones and you can clearly hear the triggered drums, guitars, bass ect.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Sorry I wasn't clear. I want to record midi-in (using V-drums as my controller and either ezdrummer or steven slate as my virtual instrument) and use the standard input with my guitar at the same time. Currently I have a Digi002R and I record V-Drums and either a Sansamp or POD at the same time. I was looking at the Eleven Rack as a second interface because I don't want to move my Digi002R everytime I'm recording at another location. I was concerned whether the Eleven Rack would record the two inputs at the same time and if there was latency with the USB 2.0 since the Digi002R is firewire. Thanks.
If all you are doing is triggering the Software drums, then yes, you can record you guitar at the same time. Midi has nothing to do with the audio. The V-drums would just be sending midi info through the midi port, while the audio inputs are sending audio through those inputs.
You can actually be recording your guitar, and 5 other audio sources at the same time, using the other inputs and digital ins, all while also triggering the midi info with your v-drums. |
Thanks for the info. I figured it was possible. I just haven't had much experience with USB interfaces except for the original Mbox that a friend of mine had.
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? | Rongpat | Eleven Rack | 8 | 02-11-2014 07:42 AM |
v drums with eleven rack | apartmentstudios | The Drum Room | 6 | 03-06-2013 11:18 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Can I use my Eleven Rack to record drums? | alexdude777 | The Drum Room | 11 | 01-14-2012 09:47 PM |
