Old 08-23-2009, 04:09 PM
EvilElfBoy EvilElfBoy is offline
Default Is yellow the new red?
So I was looking through the manual for PT 8 and I came across this.
On audio tracks, level meters indicate the level
of the signal being recorded or played back from
the hard drive. On Auxiliary Input, Master
Fader, and Instrument tracks, level meters indi-
cate the level of the signal being played through
the channel output. Green indicates nominal
levels; Yellow indicates pre-clipping (–6dB be-
low full scale); and Red indicates clipping.
Do we feel as a collective that is correct information? IMOHO I don't think that -6db below full scale should be considered "pre-clipping" Anyone else agree?
AKA - EvilElfHobo
Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4
Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified.
Multi-Platinum Pro Tools Videos
Old 08-23-2009, 04:30 PM
guitar486 guitar486 is offline
Default Re: Is yellow the new red?
I've treated yellow as red for a long time now and I feel like it's greatly improved my recordings. It's not a hard and fast rule but in general I'd say it's best practice.
----I was thinking of taking a solo in the bridge.
-Nah, I don't think that would sound good.
----Ok, well how about just a series of cool riffs?
Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK
Old 08-23-2009, 05:05 PM
PhilBuckle PhilBuckle is offline
Ever since I read Paul Frindle's comments on keeping signals around -6 I have employed that method.
Made an incredible difference to my mixing results.
So yes, yellow is the new red for me.
G5 Dual 2.7 OS 10.5.6 HD Accel 2 192+96 I/O
http://philbuckle.com/
Old 08-23-2009, 05:18 PM
I have been following that method for a long time as well, but should it be referred to as "pre-clipping'?
AKA - EvilElfHobo
Old 08-23-2009, 06:12 PM
Drew Mazurek's Avatar
Well, it is isn't it?
Not a bad way to teach people IMO these days.
www.drewmazurek.com
Old 08-23-2009, 06:32 PM
I agree, I just have some conflicts of opinion from some colleagues are far as the metering is concerned. I find this to fall into the category of Intersample Peaks.
It's pretty interesting that the nomenclature is changing.
AKA - EvilElfHobo
Old 08-23-2009, 06:49 PM
Extreme Mixing Extreme Mixing is offline
I say record lower, mix lower. Let the mastering engineer screw it up.
Steve
Steve Shepherd
Extreme Mixing
Old 08-23-2009, 07:54 PM
Mark Dann Mark Dann is offline
I stay well below -10db myself. Depending on calibration, PT's 0dB is 14 to 18dB above 0dB on an analog meter. -6dB is not enough, not even close. Unless you don't care about overloading both your analog front end, as well as every plugin and buss that comes after it.
I don't consider yellow to be pre-clipping, I consider it already clipping. Not PT at that specific point, but the audio path before it, and especially after it. With the ability to do tons of makeup gain downstream, there's no reason whatsoever to push it at the individual track level. Especially when there are often so many tracks in many productions (this effect is extremely cumulative). On an analog meter, PT's -6dB is slammed against the top. Pegged. Tilt. Game over.
Old 08-23-2009, 08:06 PM
WernerF WernerF is offline
What do your ears tell you?
Old 08-23-2009, 08:13 PM
elicious elicious is offline
second that, mark.
here, we run our levels out of the console as if it were still hooked up to the studer.
we end up with levels usually barely into the yellow or, depending on the transient nature of the signal, sometimes only green...
this is where i think many make a fundamental error;
concerned about what's coming in pt
rather than what their output device is sending.
most of the trax we get to fix and mix from other studios have driven their early stages too hard
and we don't have that anti-overdrive plug.
e
ihatetyping
Yellow Box around region beetsman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-29-2012 07:06 PM
Strike is YELLOW raydsr Virtual Instruments 5 02-01-2011 08:31 PM
Yellow box LIES to me! Norad155 Post - Surround - Video 4 02-19-2010 06:15 AM
New Strike Look: Yellow submarine, Yellow submarine.... pablotec Pro Tools TDM Systems (Mac) 3 05-07-2008 06:23 PM
Yellow Pro tools mattybones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-06-2008 04:03 AM
