HD 11.3.2 upgrade creates DAE error for Channelstrip, DYN and D-Verb plugs!![solved]
I've just updated from HD 11.1.3 to HD 11.3.2.
All works fine except I suddenly cannot open following included plugins with an "AAE error - 7054 was encountered" ; ChannelStrip Dyn3 - compressor, Dyn3-expander Dyn3 - De-esser D-Verb I have remained with OSX 10.8.5 as I need to continue to access HD 10. Also called AVID support yesterday and reinstalled Air Creative Collection 11.1. Still no go. Has anyone resolved a similar issue? THanks in advance for suggestions and hopefully a resolution process. |
Re: HD 11.3.2 upgrade creates DAE error for Channelstrip, DYN and D-Verb plugs - help
Welcome to the community.
The PT installer contains bundled Avid plugins, so you should be okay there. Have you tried Pete Gates' PT Prefs Helper?
Yes, AVID also suggested these specific plugs are included in the PT 11.3.2 update. And this is precisely my confusion - and problem - in that they're not functioning and also do not have individual Plugin installers (.dmg file) to ensure a clean uncorrupted install. All of the other AIR plugs are accessible and function perfectly. I'm thinking there must be a coding conflict within my updates because when I uninstalled 11.3.2 and reinstalled 11.1.3 these same plugs suddenly no longer worked. Interesting to note that prior to the install / update my system has been extremely stable functioning efficiently with all plugs accessible and working perfectly. Do you have any more brainstorming / house cleaning suggestions perhaps - to resolve this issue? - Many thanks in advance Stig! |
I just ran Pete Gates PT Prefs app and now have the following message: The following Plug-Ins failed to load because they are not valid 64 bit AAX plugins: AutoPan.aaxplugin BF-76.aaxplugin ChannelStrip.aaxplugin ClickII.aaxplugin Dither.aaxplugin DownMixer.aaxplugin DVerb.aaxplugin DynamicsIII.aaxplugin Eleven Free.aaxplugin Strange message… THoughts? |
Your Pete Gates Prefs Helper suggestion was step 1. I then needed to re-install HD 11.3.2 again as a Step 2. Problem solved - THank you so very much !!!! Marc |
Stig to the rescue!!
Glad you're up and running.
URGT: Registering a HD Upgrade getting a error - > SOLVED | Marco Bernardo | Pro Tools HDX & HD Native Systems (Mac) | 0 | 01-30-2016 09:50 AM |
Can´t find channelstrip in 10 after upgrade to 11. | [email protected] | AAX Plug-ins | 1 | 07-13-2013 07:07 AM |
Verb plugs | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-11-2004 10:18 AM |
Help! Mac freezes when adding verb-plugs | Magellan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-03-2002 07:46 AM |
record error/lockup creates HUGE AUDIO FILES!!! | david kowalski | Pro Tools TDM Systems (Mac) | 2 | 03-23-2002 08:55 PM |
