What OS X for Protools 2020.12
What OS will be the best
For MacBook 2012 Ssd 16gb ram PT 2020.12 Now is working with Capitan, but gives “Error launching video engine” Thanks👍👍
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: What OS X for Protools 2020.12
Hola Jascha: with that laptop you can upgrade to Catalina fine, I would recommend Mojave though, and I got the same problem of the video engine not starting.
Felipe Gonzalez A. Avid ACSR Elite Dante Certified http://felipousismix.wix.com/felipousismix Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins |
wich os are you working at the moment Have you solved the “not launching video engine error” Thanks I will wait your inputs
M dicen ir a Sierra la mayoría Don’t know if someone else got this problem Most says go with sierra But no one confirm gets this error with video engine I only hope get solved I’ll do a new OS Instal and clean instal of Protools In a new SSD My Mail [email protected] Wasap +569 93465105
Check here
https://avid.secure.force.com/pkb/ar...ails-to-launch Problem: On macOS the Pro Tools Video Engine will not finish launching (gets stuck on "Waiting for Video Engine to launch" message). Solution: Check to make sure your boot volume is formatted Case-Insensitive. Case-Sensitive boot volumes are not compatible with the Pro Tools Video Engine. On my case, my HDD is Case Sensitive, so I need to wait until they support this feature in OSX.
Reinstall the OS, and don't use the case-sensitive option when formatting the drive, going into the Disk Utility before installing, will make the trick.
I’ll go
I've had the best luck with Catalina, and by an appreciable margin. It's quicker and smoother than previous OSs.
This is a tough subject because each person's configuration will vary, depending upon what hardware and software you're using, and the versions of that software. For some (like me), Catalina whipped some problematic issues into shape, so to speak. And as mentioned, it's also largely helpful to install a new OS from scratch, if possible. I did this just yesterday on a different machine and the difference was night and day. The old machine had been upgraded with new OSs installed on top of the previous one. It was getting slow. After the fresh install it's like a brand new computer (even though that particular one is from 2012). |
Big Sur & Protools 2020.11 | Obsidian Dragon | macOS | 20 | 04-25-2021 10:21 PM |
