Old 12-09-2008, 10:12 AM
crizdee's Avatar
crizdee crizdee is offline
Default Fine adjust fader in edit window caput! command+adjust
Command+adjust to get a fine adjust on the main channel fader from the edit window doesn't work!!
When did this stop working? mostly use my control 24 so haven't noticed till now!
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-09-2008, 01:56 PM
gonzolagonda gonzolagonda is offline
Default Re: Fine adjust fader in edit window caput! command+adjust
I don't think it's ever worked on the pop-up fader that appears when you click on the I/O fader level display on the Edit window. Only works on floating fader channels and the Mix window AFAIK.
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc.
Old 12-09-2008, 03:55 PM
PhilBuckle PhilBuckle is offline
Strange that you you mention it because it's been annoying me lately.
But I honestly can't remember if it ever did work.
If it didn't then why am I missing it?
G5 Dual 2.7 OS 10.5.6 HD Accel 2 192+96 I/O
http://philbuckle.com/
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
How to fine adjust volume and pan faders? Huilop Pro Tools 10 4 01-26-2012 03:39 PM
Waves 7 plugs fine adjust mode now broken! and also don't work with control surface crizdee Pro Tools TDM Systems (Mac) 27 02-17-2010 09:52 AM
Track Height Adjustment - EZ. What about Fader Width Adjust markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-23-2007 01:33 PM
FADER FUDGE-QUICKSAND - CANNOT REALLY ADJUST DURING PLAYBACK Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-10-2007 05:48 AM
