D-command firmware RESET and Xmon not working properly
Hello all,
I just bought a 2009 D-command (black one) with a XMON (REV H). Tested it at the previous owner. Xmon was working properly, except that he had to replug the Xmon after a power down. Now I've hooked it up to my system, did a firmware upgrade (from 7.xxx to 10.xxx ). So that is looking good. When I try to upgrade the firmware of the Xmon (which is running now on NO firmware ------) I get error message 1. When I power down the D-command, the firmware resets to 7.xxx again. I just got it to work, for once, Xmon firmware v11 was downloaded and everything was working fine. Then I powered the D-command down because I wanted to leave, and now it's reset again to 7.xxx firmware and the Xmon firmware is gone. And now I get the firmware download error 1 again. The 15 pin cable that came with it didn't seem like a "Digidesign" cable. It's a grey/melee coloured cable with a length of 3 meter. Could this be the problem? I've also tried another standard 15 pin cable with more length. This was before I got it working once. I've rebooted, changed power cables, sockets, reset he D-command, booted Xmon with mute button pressed (green mode). Anyone got some thoughts? |
Re: D-command firmware RESET and Xmon not working properly
Update 18-09
Made a new custom cable with the right pinout: http://akmedia.digidesign.com/suppor...db15_44797.pdf Instant succes. Could be helpful if someone encounters the problem to double check the 15 pins control cable. |
no firmware on XMON | snkishore18 | ICON & C|24 | 12 | 01-09-2024 01:37 AM |
XMON loses firmware | Adamsound | ICON & C|24 | 1 | 04-19-2015 11:01 PM |
C|24 Firmware reset? | Marsdy | ICON & C|24 | 1 | 08-18-2010 10:18 AM |
XMON Firmware Update | Avid | General | 0 | 12-15-2005 08:15 PM |
XMON Firmware Update | Avid | ICON & C|24 | 0 | 12-09-2005 10:51 PM |
