Old 09-27-2020, 03:28 PM
dmitch dmitch is offline
Default Re: Direct Box for Bass into PT - Recommendation?
Originally Posted by skyko View Post
Avalon U5 if your budget allows...Never ever any of my basses did sound better.
I second that. Best sounding DI I've ever used for bass or electric guitar. I've used it for years, exclusively, for recording guitar and bass with PT.
Old 09-28-2020, 08:03 PM
johnbarnesiii johnbarnesiii is offline
Originally Posted by Darryl Ramm View Post
8 Pre has 8 DI or mic combo inputs. So start there. No reason to be buying anything else unless you are unhappy with the results, and especially if you have hum issues then try a transformer based DI.
Thanks Darryl. I’m wanting to record the miked amp (dirty tone) and the direct in (clean tone) simultaneously though. Wouldn’t I need the DI to split the signal so I can record both tones simultaneously? Asking bc I’m not sure.
Old 09-28-2020, 08:13 PM
JFreak's Avatar
JFreak JFreak is offline
Two things.
First of all you need to record both signals from same interface so you have same latency compensation.
Second, you need to measure the distance from mic to speaker, then later on adjust the mic'd signal which is "late" compared to direct.
I have had great results with Focusrite ISA1 both in studio and live environment. But whatevver gear you use, you need to know that the mic'd signal needs to be adjusted depending how far you have placed the mic. NOTHING will change that fact.
Janne
Old 09-28-2020, 08:21 PM
Ben Jenssen's Avatar
Every DI box I've ever seen has had more than one output. One goes to the interface, and one to the amp.
Old 09-28-2020, 08:58 PM
There are many ways to skin a cat.
I was thinking the most basic like start just recording using a DI and see if you like the sound. See if you like the sound of that wet through an amp sim.
Your 828 Mk II has mic send outs, you can try DI into the interface and out the send into the amp, turn it down or attenuate it.
If you have a guitar/bass AB/Y splitter you can likely use that to split signals with no problem. A straight Y cable splitter may get you into ground loops, but you can also try that if you have a cable handy.
I am not saying this is better than a nice DI box, especially many of the ones mentioned here. I'm just suggesting you start playing with that you have and see where that takes you.
  #16
Old 09-28-2020, 10:47 PM
Oh gotcha, thanks!
  #17
Old 09-28-2020, 10:53 PM
Yes understood. I was just responding to Darryl’s suggestion that I wouldn’t need a DI at all if I went straight in to the Motu 8Pre, so I was letting him know I was wanting to capture two different sounds (one clean and one dirty) at the same time, illustrating that in this case a DI may be a good way to go. Thx.
  #18
Old 09-29-2020, 12:55 PM
c-tone c-tone is offline
The Avalon U5 is excellent, but for a lower budget choice, I recommend the Countryman 85 DI, particularly for rock music.
www.clifnorrell.com
  #19
Old 09-29-2020, 05:36 PM
Damn this thread has me wanting to buy a whole lots of DI boxes. I can't afford to do that. I have no money left after recent guitar pedal shopping. I swore I was going to stop that, especially being on the waitlist for a Fractal FM3... OTOH rest assured dear bass and guitar community that JHS Pedals should be in business for years to come
  #20
Old 09-29-2020, 09:27 PM
Top Jimmy's Avatar
Check out the Radial JDV. Radial bought the design from John Vrtacic who’s original hand-built units were part of the secret sauce at Little Mountain.
James Cadwallader
Recording bass direct to 001 guitaramundo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-12-2002 03:19 PM
Recording guitar and bass direct - help! halfloaded 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-07-2002 04:35 PM
Direct Bass buzz/hiss Pako 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-28-2002 12:09 AM
Bass guitar strings recommendation for Hard Rock music geminirand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 27 02-06-2002 10:51 AM
What's the best BASS direct box direct to PT recording dw Tips & Tricks 18 05-13-2000 08:08 PM
