Help with Output Routing PT 10 and Apogee Ensemble.
Thanks for any advice you can give.
I am pretty sure this is something simple but I cannot for the life of me find an answer. I need to re-amp two channels out (Analog) of my Ensemble and then route back into Pro Tools via Ensemble. My problem is setting up the output routing. I bought the DSUB cable which gives me 10 (8 useable) analog outs... I need to be able to access these as MONO outs...but the outputs all show up as stereo outs.... Same for the dedicated G1 and G2 outputs for re-amping with Ensemble. In one of my sessions I pulled up the output list and the Guitar G1 and Guitar G2 showed up as Mono outputs... I pull up another session and only a stereo output is shown. Anyone know how to configure the outputs to give me the option to output to Mono Outs via my DSUB or G1 G2? Thanks in advance. Here are a couple screenshots to show you what I am dealing with....the first screen shot shows a session where the Guitar Outputs show up as Mono Outs...But I could not figure out how to get the SUBD Outputs how to show up as analog outs.....the 2nd screen shot is how all my other sessions show up...with no mono outputs. Apparently I cannot embed this screen shots so here are some links if you care to look... http://www.sirtitus.com/images/Good.png http://www.sirtitus.com/images/Bad.png |
Re: Help with Output Routing PT 10 and Apogee Ensemble.
Hi, You can configure all this in I/O setup. You can create and name mono outputs, or create mono sub-paths under a stereo or multi-channel output. It's a very nice way of customizing Pro Tools' I/O to suit your setup. By default, Pro Tools typically creates stereo outputs with mono sub-paths.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Routing Vienna Ensemble Pro to Pro Tools 9 on one computer? | StinkyStan | Pro Tools 9 | 8 | 03-29-2013 06:21 PM |
Apogee ensemble with C24 h | remusjacobs | macOS | 0 | 12-03-2011 02:45 PM |
DIGI 003 + Apogee Ensemble + Apogee Big Ben = World Clock | marcioguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-11-2011 02:24 PM |
PT9 & Apogee Ensemble | williaint | Pro Tools 9 | 2 | 11-30-2010 06:15 AM |
Apogee ensemble for 8 more A-D ins on OO1 PCI? | voltech | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-07-2007 09:16 PM |
