Old 04-29-2010, 12:14 PM
Qcthakidd Qcthakidd is offline
Post Midi [emulated] in Protools (not sending signal)
im using Pt 7.4 with command 8 & midiman 2x2... When i didnt have the command 8 i was syncing the Roland x6 wit the midiman perfectly but for some reason or another when i installed the drivers for the command 8 it made the midi inputs/outputs have [Emulated] next to them now i cant sync my Roland x6 as slave ((Not receiving the midi beat clock signal!!!)) I want to find out how to clear the [emulated] from PT..... Even if i uninstall Pt and reinstall it still says the samething and i caint even sync my Roland x6 to protools!!!
Old 12-27-2010, 08:45 AM
twontw twontw is offline
Default Re: Midi [emulated] in Protools (not sending signal)
I'm having the same problem with my Motu and ProTools 9.
The midi-out are (emulated)...
Have you solved this problem?
Emulated MIDI notedmusic Windows 20 07-22-2018 03:58 PM
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] bbirney Pro Tools M-Powered (Win) 8 05-19-2018 06:58 PM
SRO Card not sending signal madmiky VENUE Live Sound Systems 3 08-07-2010 08:27 PM
[Emulated] MIDI outs are not sending data rygundo MIDI 1 02-10-2010 08:16 PM
sending analog signal out of 001 badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-22-2003 07:22 PM
