does anyone use a comp on an aux buss?
on another post i mentioned doing this and im wondering who else does this .....chas
Digi 002 on windows xp pro .. pentium 4 @ 1.6 ghz....intel 845 chip...gigabyte p4 titan MB....seagate hd.....40 and 120 gb @7200....1 gig of ram |
Re: does anyone use a comp on an aux buss?
Not me...everything needs it own settings usually..
5198 Studios |
I've actually heard of a technique (but never tried it) where you send the drums to an aux buss with a compressor that really pumps, and slowly bring up the levels until you get a good blend between the 2. Sounds like an interesting idea but I've never tried it.
PT LE v8.0 digi 002R digimax lt PowerPC G5 dual 2.0gz 7 gigs ram 2 TB HD Tannoy Monitors Yamaha NS-10 |
All the time. Like if I want to compress a group of BVs or a group of rythm guitars. Many different scenarios. Just in the same way we would Buss and compress/ EQ different groups on an old 8 buss analogue desk. Best regards, Big D
INTEL QUAD XEON INTEL S5000XVN serverboard 4 gig Fully Buffered Ram (About to add more) 3 x WD500gig SATA, 1 x WD1T32mb SATA cache Green NVIDIA Geforce 7300le, Command 8,HD2,192,Massive Pack 4 Windows 7 64 bit PTHD 9 |
Yes, I do it and am happy with the results. It does reduce CPU drain.
J.D |
I used to buss all my drums to a stereo AUX track and use a separate compressor and EQ on it. It sounds good if done correctly. I tend to just do the toms now but depends on the drummer...
Not a bad technique though. I would use EQ and compression on the drums individual tracks, then pipe it to a AUX track that had a tad more compression and use that 1 fader as an overall level. Submixing.... that way you get your individual drum levels, hide them and only rely on that one fader to control the drums. Hope that this helps? - Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
thanks for the replies i thought for a bit i was alone on this......i started doing this out of frustration of pegging my cpu all the time and this definetly helps in that regard.....ive been setting up several aux busses and using one for drums and one for vocals and one for guitars etc....its also all nondestructive so your not commited to nothing like you are with processing and printing regions which i found to be alot of guesswork.....it aint as cool as it would be to be able to use all seperate plug ins but for my pc i thik its a neccessity.....check it out if you aint tried it maybe youll like it.......chas
Duende SSL G Buss Comp... Is it worth it in PT8 HD | M2E | Pro Tools TDM Systems (Mac) | 24 | 06-18-2009 02:55 AM |
Would i get any latency w/external comp for buss | Detuned6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 04-25-2006 12:38 PM |
Waves SSL EChannel & G Buss Comp | Shan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 21 | 02-08-2006 01:09 AM |
using an outboard comp/limiter on mix buss | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-14-2004 01:38 PM |
Outboard comp on the master buss | bassmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-12-2002 02:21 AM |
