Condensor mic clipping with Input Signal at zero!!
Hi there,
I'm recording a vocal using a Midnight Blues 4000C Condensor microphone, via my MBox 2 and into Pro tools LE 7.1.1, but even with the MBox Input set to zero, the vocal is clipping and distorting in Pro Tools! How is that even possible?! The mic is plugged into the XLR input, and i have the pad and phantom power both off on the MBox since the mic has its own phantom power. This seems to defy science to me, but there's probably a very simple answer. Can anybody help? Thanks, Ewan |
Re: Condensor mic clipping with Input Signal at zero!!
Hi ewan.
What computer are you using? Also a couple of basic trouble shooters. Does it do this; without the mic plugged in, with a different mic but same XLR cable, with different cable? Also is the cable properly housed between the mic and its power supply? Sorry to ask the obvious but most of the time that is where problem lies. A:)
I Love Audio!!! |
Hi Ace,
I have a Mac Powerbook. I was using an XLR to XLR which I swapped for an XLR to 1/4 inch jack, but the problem's the same. I don't have another mic unfortunately. This is really bugging me. thanks for your help. Ewan |
Lots of mics are "hot" in themselves. That's what damping pads are for. Is there a pad button on your mbox? That says, like -20 or something? Use it.
If you don't have a pad, there are attenuators out there. Small xlr things that you just plug in between the mic cable and the pre amp. And don't worry if you first push the pad button, and then have to turn up the gain. That's how it works. IHTH
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Ben's right, use the pad on the M-Box that is what it is for.
If the output of the mic is still too hot (that's likely what the problem is) Shure makes a handy in-line attenuator: http://www.bhphotovideo.com/c/produc...ttenuator.html
Learn to listen. Listen to learn. |
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
clipping (hot signal) | jordanp | Pro Tools Express on Windows | 2 | 01-20-2014 12:08 PM |
guitar signal is clipping on mbox despite gain all the way down | World Spirit | macOS | 1 | 12-13-2011 06:08 AM |
Digi 003 signal clipping | kvnlnt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-14-2010 03:52 PM |
digi 002/003 clipping signal on HD system. | T-Jac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-02-2009 01:05 PM |
Hot Signal Clipping? | AnalogTree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-04-2000 07:34 PM |
