I'm have a few questions/issues concerning Digi 001
I have an MBox that I'm running 6.1 with and I wanted/needed more inputs mainly for drums. I record the drums onto Tascam DA38's, bounce 2 tracks at a time and then sync them. It's worked for me but I've grown tired of it. So not being in the position to purchase an 002 much less an 003 I got what seemed to be a good deal on 001, $75. That being said...
I hooked up the 001 and Pro Tools 6 (for the MBox) recognized it and let me choose the 001 as the playback engine. I am able to record audio in and I see the wav files in there however I'm not getting any audio out from any of the outputs including the headphone output except when I'm recording and in monitor mode. When I switch back to the MBox it works just like it should. I've checked all of my connections numerous times and everything is set up correctly. I've tried installing the version that came the 001 but the install wizard encounters an issue and bails out so I haven't been able to test it with that yet. I've uninstalled everything and I still do not hear any audio out the 001. Another issue is that when I adjust the input levels of 3-8 on the 001 they do not change. Could it be a hardware issue? Is the 001 compatible with MBox 6 software? Any help would really be appreciated, I've been racking my brain on this for hours. Thanks. btw... The guy that sold it to me said he had no issues with it and would give me my money back if I couldn't get it going. |
Re: I'm have a few questions/issues concerning Digi 001
The 001 is compatible on XP, and up to version 6.4. So this would depend on precisely which version of PT you have now. BUT if the M-box drivers are already in place, you will still need to install the 001 drivers.
Thanks, sw rec.
I updated from 6.1 to 6.4 and still no luck. http://archive.digidesign.com/compato/xp/001/ My guess at this point is that it could be a hardware issue. |
If you are running V6.4 on XP sp2 you will need cs6 and cs9 installed.
Thanks Tom.
I've updated & installed cs6 & cs9 but still no luck. |
Sorry if this is off-base, but have you disconnected the Mbox?
Yeah, at one point I disconnected everything including the PCI card and re-installed 6.1 from the disc then did the update to 6.4.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
No I didn't delete the prefs, how do I do that? Yeah, set the I/O to default.
From this thread:
http://duc.digidesign.com/showthread.php?t=133039 Delete DAE and Pro Tools preference files See below for a utility that will do this for you automatically! Start Menu > My Computer > Local Disk(C:) or correct hard drive (click "show the contents of this drive" if the files aren't displayed) > Program Files > Common Files > Digidesign > DAE > Right-click on the DAE Prefs folder and delete. Start Menu > My Computer > Local Disk(C:) > Documents and Settings > "Your user folder" > Application Data > Right-click on the Digidesign folder and delete. (If the Application Data folder is not showing: Tools Menu > Folder Options > View Tab > Select "Show Hidden Files and Folders" > Click Apply and OK.) - Delete the Digidesign Databases folders for all hard drives This step can be useful when receiving random 'assertion' or 'neoaccess' errors, especially when recording or saving. Start Menu > My Computer > Local Disk (C:) > Digidesign Databases > Right-click on the Digidesign Databases folder and delete. Repeat for all hard drives. Start menu > My Computer > Local Disk (C:) > Program Files > Digidesign > Pro Tools > Databases > Right-click on the Volumes folder and delete.
ProTools 9.0.5, iLok issues, Digi 003R+ issues | zachbot | Pro Tools 9 | 6 | 10-12-2011 08:19 PM |
Questions about PT ISSUES | Builder for PT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-25-2007 11:03 PM |
PT7 issues/questions | redchair | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-25-2006 11:51 AM |
USB Hub Issues. Questions. | Shawn B | Pro Tools TDM Systems (Mac) | 2 | 02-25-2004 09:28 AM |
5.1 ISSUES/QUESTIONS | naman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-27-2001 06:43 PM |
