Old 03-01-2010, 09:34 AM
mwelles mwelles is offline
Default DAE error -9126
Hi all,
I have moved some files from my primary work drive to a RAID drive. When I go to open these files, I get a DAE error -9126, and the files fail to open.
Please help! I currently have no way to open these! I have much work to do.
I am running a Mac with Snow Leopard, plus PT v8. This a HD system.
Thanks, much, all!
Guy
Old 03-01-2010, 09:40 AM
Sean Russell Sean Russell is offline
Default Re: DAE error -9126
I didn't know RAID drives were supported. There are at least two other threads in the last 24 hours with problems with RAID config's.
The session works ok from your usual work drive?
... but does it help the chorus?
Old 03-01-2010, 09:15 PM
Yah, that, indeed, appears to be the problem. Yet another case of operator error. : ) Thanks for your help!
Old 05-03-2012, 09:33 AM
Joan Riera Robuste Joan Riera Robuste is offline
Hello,
I have the same problem DAE error -9126. I am saving my sessions to an external RAID drive that I just bought, and, although I can open them from my older drive, I can not open them from the new. What can I do ?
Thank you !
Old 05-07-2012, 12:11 PM
moondoggie53 moondoggie53 is offline
As I am having similar problems, may I ask: 1) Are either, none or both of the drives running at 7200 rpm; I will assume you have updated drivers. I am led to believe 9126 is a hardware error, so RAM could be an issue, but I see you were able to open the files previously. OK. I'm out.
DAE Error -9126 Parches Pro Tools TDM Systems (Mac) 1 02-10-2012 09:56 AM
DAE error 9126 Kornfed Records Pro Tools 9 10 08-06-2011 06:57 AM
PT9 DAE error -9126 bigtuna macOS 1 07-21-2011 03:30 PM
DAE error -9126 Pompolius 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-01-2011 12:05 PM
DAE error -9126 Oldskewl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-03-2010 06:39 PM
