Old 06-23-2019, 04:49 AM
Mark Frith Mark Frith is offline
Default Roll Back HDX Card firmware???
I've been using PT 11HD with HDX core for about 4 years. It's fine. I like the newer versions but haven't been able to afford to upgrade.
however, i decided to try a demo of the new 2019/5 software. during the install i was prompted to 'upgrade' the firmware on my HDX card. Then the software didn't work because apparently I need to buy a digilink licence for an extra £250. I added this up with the software upgrade price and have changed my mind. I'm just not making enough to justify the cost. I think this should be perfectly acceptable. Thats the point of a demo, right? However. now i have gone back to pt11 which i own outright i can't get my inputs to work, presumably because of this HDX firmware update.
is there a way to roll back the firmware to my original one? surely there must be a way to revert back. I've tried this https://avid.secure.force.com/pkb/ar...are&popup=true But nothing seems to be happening. Im not getting a prompt to update my firmware.
Any advice would be gratefully received. Thanks
Mark
Old 06-23-2019, 09:04 AM
peterle peterle is offline
Default Re: Roll Back HDX Card firmware???
there is a tiny button on the edge of the board , which should ,
as far as i remember , reset the firmware .
regards
foley artist , soundeditor
Old 06-23-2019, 09:59 AM
Yes, thanks for your reply. This is the procedure outlined in the link I shared in my original post. Doesn’t seem to be having any effect though...
Old 06-23-2019, 11:06 AM
BScout BScout is offline
What is your system specs — specifically where is your HDX card located in? Due to the need of power being applied through the process, the firmware reset will not work if the card is in a chassis.
Old 06-24-2019, 12:54 AM
Ahh. Now that is useful information, thanks.
Thankfully I still have my Mac Pro 5.1 so I will pop the card in there and have a go.
Cheers
Mark.
Old 06-24-2019, 05:44 AM
.....and...we're back.
Thanks M
Any way to roll back to 1.0.7? derker Avid S1, S3, Dock and Control App 13 05-31-2018 09:29 AM
Can you roll back? suicune Pro Tools 12 2 11-17-2015 03:35 AM
Roll back from 9.0.5 to 9.0.3 ? LSNY macOS 17 09-28-2011 09:32 AM
How do you roll back from 8.0.4 to 8.0.3? HELP!!! JayStyles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 08-20-2010 05:08 AM
6.9 firmware how do I roll it back? neatguys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-23-2005 10:36 AM
