Command 8 fader resolution?
Just wondering if anyone knew what the actual resolution (10bit,etc) of the faders on the unit? Thanks. |
Re: Command 8 fader resolution?
the resolution is 1024 steps, so pow(2,10). I think it's right to say 10 bit.
G4 MDD dual 1.25 2 Gb ram OS X 10.3.9 PT 24 Mix+ 6.4.1 cs4 888l24 1622 commandl8 |
Is this the same resolution for Pro Control and ICON? Their resolutions are also 10 Bit, right?
I'm sorry, but I don't know. I worked with pro control, but in another studio then mine. I never touched an icon yet!!!
antonino
Anyone knows? Is the fader resolution on Command 8 same as ICON, Pro Control or Control 24?
Hello all... bumping this up to the top. I'm thinking about buying ten Command-8's.
Are the faders indeed 10-bit? Is this data communicated into the session automation data? (or is it munged down to 8- or 7-bit) I noticed the connection is USB so that shouldn't hurt... |
I'm not sure about this but you but I believe you can only have one command8 or two command8's per computer. Definitely look into it before you buy them all.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
Command 8 fader resolution | lululu | ProControl, Control|24, Command|8 | 7 | 10-22-2009 02:37 AM |
What is the fader resolution on the 003 factory? | lamp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-30-2007 09:39 AM |
Fader resolution in PT | johnnyv | Pro Tools TDM Systems (Mac) | 9 | 05-14-2001 05:57 AM |
C24 Fader Resolution | fdc | ProControl, Control|24, Command|8 | 9 | 03-12-2001 12:53 AM |
Control24 fader resolution? | Peter Duemmler | General Discussion | 8 | 01-26-2001 12:38 AM |
