Old 03-26-2021, 02:53 AM
huzzam huzzam is offline
Default 2021.3 constant hangs
Is anyone else getting constant PT hangs when doing simple edits? I wasn't seeing this on 2020.12, but now when I do something simple ~ e.g. zoom in on a waveform and try to drag the crossfade over, Pro Tools hangs completely, requiring a force quit.
Happened five times in a row, within one minute of opening the session. Restarted the computer, no other apps running (not even Time Machine or Google Drive Sync etc). No time to troubleshoot, so I'm gonna go back to 2020.12 and see if it works better.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Old 03-26-2021, 07:02 AM
Default Re: 2021.3 constant hangs
FYI I rolled back to 2020.12 and the problem has disappeared. No one else is noticing this issue?
Old 03-26-2021, 07:26 AM
Southsidemusic's Avatar
Nope runs great here PTU 2021.3. No hangs or issues and we run 200+ track songs with many VI and automation althoguh barely no plugins as we use hardware. We do have melodyne 5 and some guitar cabs from UHE and a few soothe2 tracks and thats about it. VI tracks are many (30-40) and some bounced in place but still atleast 30-40 VI tracks with synths and guitar stuff.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-26-2021, 07:42 AM
off the wall's Avatar
No issues so far here. What GPU do you have in your Hackintosh? I wonder if some graphics acceleration is having issues.
offthewallproductions
Old 03-26-2021, 07:44 AM
grayter1 grayter1 is offline
Running super solid here. Specs in sig. Current session has several heavy VI's - Omnisphere, Keyscape and Pigments. All running fine at a buffer size of 128. I could be running at 64, but I don't see the need atm.
No issues here.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 03-26-2021, 09:18 AM
No discrete GPU, just the integrated graphics of the i9, uhd630. But anyway, it's a permanent hang, requiring a force quit. Usually graphics issues seem to last just a few seconds.
Interesting that it's just me, though. When I get through this bit of work I'll try again and do more troubleshooting. Luckily 2020.12 is rock solid for me... and I'm way back on Mojave (thanks to two 32-bit apps I continue to need), so no hurry to upgrade.
Old 03-26-2021, 12:49 PM
Perhaps try moving plugins to unused folder and try again. If things run smoothly, start moving the plugins in back one at a time and test to see if a particular plugin is causing the problem. It is a tedious process, but so often plugins are the cause of issues.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 03-26-2021, 01:34 PM
yep thanks :) i know the drill... i *also* know the drill about not upgrading when you're in the middle of a project, but i did it anyway
will report back here in a few weeks, once the current project is done. always appreciated, señor dragón!
Old 03-26-2021, 01:53 PM
Becharax's Avatar
Becharax Becharax is offline
okay I am getting those freezes .... especially when I open UAD console 2 and arm record a track in Pro Tools .... for no apparent reason ... is it a bug ?
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 03-26-2021, 01:54 PM
Becharax's Avatar
is it possible to revert back by just installing 2020.12 or should I uninstall 2021.3 first ?
System Details:
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Any benefit to TDM in 2021? akopp Pro Tools TDM Systems (Mac) 41 01-12-2022 11:05 AM
PT 2021... Catalina? Or Big Sur? Eric Lambert Pro Tools 3 03-26-2021 12:41 PM
Come on! 2021 already. Just issue what’s right. DetroitT Pro Tools 2020 0 03-05-2021 05:35 PM
