Snow Leopard or Lion with PT10.2 HD
Hi Team,
I have an 8 core Mac Pro 2.1 (Old version) that I want to run PT10HD on. It's the only thing I will be running on this machine. Is there any advantage in using OSX 10.7.x over 10.6.8 when setting this up? I think I have noticed my Mac Mini (core duo 2.0Ghz) and my Macbook Pro (core duo 2.4Ghz) both seem a bit sluggish since Lion was installed. If there is no real advantage then I'll just go with Snow Leopard. All tips, observations and experiences welcomed. Cheers Lizardpoint |
Re: Snow Leopard or Lion with PT10.2 HD
If you think what is best today Snow Leopard is the way to go. Lion is making your computer more sluggish. I have the same experience as you, I updated Macbook and iMac with Lion but fortunately not my Mac Pro.
However if you are planning for tomorrow I suggest you to wait for Snow Mountain which will be here within a few weeks and then you have to add a couple of weeks for AVID to say it is OK to run Pro Tools on it. So...skip Lion for now
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
You are absolutely right.
That is great advice. As far as planning for tomorrow I think my Pro Tools roller coaster ride is soon to end as I have too much gear that is not supported beyond PT10. Thanks again for your help and very sound advice. Cheers Lizardpoint |
10.2 is running HD 6 on my 8 core Mac Pro on 10.7 with not a single hiccup here.
my machine is pretty loaded but it should not do that
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
It definitely should not do that. It's definitely not the the combo of OS and P Tools version that is the problem as it is working well for tons of people. It's gotta be system specific.
it does not crash every day
i may have had a bad session or bad PT file that need to be cleaned with the util.....sometime when i go real real fast in editing and with a loop going on sometimes is when it also doesn't seem to like that
snow leopard or lion for PT 10.3.7 | queemacarthur | macOS | 3 | 11-04-2013 09:12 AM |
Would you go from Snow Leopard to Lion (not Mountain Lion) if you could? | EricWillhelm | macOS | 9 | 01-11-2013 10:55 AM |
From Snow Leopard to Lion... | heabow | macOS | 8 | 06-06-2012 08:40 AM |
PT HD 10: Snow Leopard or Lion? | johnnyv | Pro Tools 10 | 2 | 01-31-2012 09:47 AM |
PT10: More Efficient on Snow Leopard or Lion? | audiosf | macOS | 3 | 10-27-2011 01:20 AM |
