Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 07-06-2020, 10:50 AM
grameswan grameswan is offline
Default Strange Folder Shortcut problem in Edit Window
Only In the Edit window Shift F always opens and closes the same folder even if I select another folder it still opens the same folder. From preliminary
fooling around it seems to always open the last folder created.
Happens with both Basic and Routing Folders. I can still click on the folder on the track with my mouse and it works correctly but the shortcut doesn't. Everything seems to work as properly in the Mix window.
I'm Running Pro Tools 2020.5.0 and latest Avid Control with the latest Firmware update for the Artist Mix on a 2018 Mac Mini 3.2 Ghz i7 32G Ram MAC OS 10.14.6.
Old 07-07-2020, 02:34 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Strange Folder Shortcut problem in Edit Window
Hi, It will open or close folder tracks in the Edit window depending on where the edit cursor or edit selection is. I tested that shortcut and it works for me.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 11-08-2023, 07:15 PM
ZachMcNees ZachMcNees is offline
Anyone ever figure out a solve for this? Just started happening to me.
Strange Folder Shortcut problem in Edit Window joeshepard Pro Tools 2020 0 06-04-2020 01:30 AM
Any shortcut to audition selection in edit window? Tom M macOS 3 07-19-2013 10:45 PM
Strange Edit Window Bug? EarHole Pro Tools TDM Systems (Mac) 0 02-24-2009 09:19 AM
toggle mix and edit window shortcut daven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-02-2005 02:02 PM
Mix to Edit window shortcut Cliffy_Boy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-29-2003 08:45 PM
