Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-10-2020, 02:29 AM
dobes dobes is offline
Default m-audio Keystation not working
Hey everyone,
I have a new surface pro 6 (Intel i7, 16Gb RAM, Windows Home 64bit), and have installed pro tools 2020.3 with their default plugins only.
I have a Zoom UAC-2 USB3.0 hardware interface that i have used on my previous surface with pro tools 10 with no issues.
I have a m-audio keystation 88 usb devices.
When protools is running via ASIO4ALL the keyboard works with protools, however when my Zoom hardware is running it does not.
Things ive tried:
  • USB Keybord turned on prior to opening pro tools
  • Latest drivers installed
  • Pro tools loaded as administrator
  • Midi Thru is enabled
  • Instrument track, with basic piano plugin, set to record
  • Preferences - set default thru instrument to none, first, and also the keyboard
  • Midi input devices - the keyboard is shown and ticked
  • The keyboard is show as an input device on the track
  • I have run midi-ox, both on its own and while pro tools is running, and it is registering keypresses.
  • Midi Studio - i tried setting up in here as well just in case.
Possible thoughts/issues
  • The keyboard shows as emulated.
  • There are other midi devices shown from the Zoom devices, maybe there taking priority, as those ones are highlighted in orange on the menus?
Any ideas would be appreciated.
Thanks
Old 04-10-2020, 04:16 AM
Default Re: m-audio Keystation not working
It sounds like you regularly switch between the internal audio and the Zoom for audio I/O. To switch between the two hold down the 'n' key on the computer while starting PT and you'll be able to select the interface you want to use.
The choice of audio interface shouldn't have any effect on whether your keyboard is working or not. MIDI is digital and not audio. In PT's preferences on the MIDI page set the default through instrument to first selected track.
Also make sure you have turned off power savings measures for the USB ports - this is done in Windows Device Manager from inside the Windows Control Panel.
Jack
QAPLA!
Old 04-10-2020, 07:16 AM
Thanks for the tips.
I have turned off power saving measures for USB and set the default instrument to be the first track.
If i load pro tools with ASIO4ALL then the USB keyboard is working correctly.
If i load pro tools with the ZOOM Audio hardware then the USB keyboard is not working.
Running out of ideas as seems like the hardware is preventing protools from interfacing
Old 04-10-2020, 08:56 AM
ChuckS ChuckS is offline
Firmware and drivers on the Zoom UAC-2 up to date? Class compliant switch set to off?
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-23-2024, 09:10 AM
germanretu germanretu is offline
I attach an image of how I randomly set my Keystation Mini 32 MK3, and MIDI works now in Pro Tools
Old 02-24-2024, 11:42 AM
AFAIK, with Windows, you MUST go to Setup>Midi>Midi Studio and create/configure your controller before it will work. This has been true of all of my Windows setups going back to 2003(Pro Tools 6) and I have used several different midi controllers over the years, sometimes with as many as 3 operating at the same time(recording a Roland TD10 kit triggering Superior Drummer, a Yamaha Motif es8 controlling MiniGrand and a 3rd keyboard controlling DB-33).
Keystation 49e Stopped working...any ideas?? asiabackpacker macOS 7 02-10-2015 10:54 PM
Keystation 49e not working in 8.0.3 Chuck1073 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-10-2010 12:23 PM
m-audio keystation 49e chalkoutline MIDI 21 01-31-2007 05:06 PM
M-audio keystation 49e Palli-Moon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-16-2005 07:24 AM
M-Audio Keystation 49e Randirainbow MIDI 0 10-17-2004 02:48 PM
