Old 01-09-2019, 04:24 PM
analog orange analog orange is offline
Default CPU usage is cut in half when I switch from...
CPU usage is cut in half when I switch to the built in output on my 2012 mac mini vs using my Eleven rack connected via USB to the USB 3 ports on the mac mini. Is there a fix for this?
High Sierra
16gb ram
Protools Ultimate 2018.10
Old 01-14-2019, 02:51 PM
Sam C's Avatar
Sam C Sam C is offline
Default Re: CPU usage is cut in half when I switch from...
I wonder if the Eleven rack is not usb3 compatible? If so, would this explain it?
Sam
Old 01-19-2019, 04:12 PM
I know there was an issue with this whenusb3 started to become the norm. Stability is decent now BUT the CPU usage has gone up and latency can't be set as low. I'm getting a minimum improvement of 40% when using the built in sound. Really don't want to spend money on a new interface right now. Almost as unsexy a purchase as a PTHD update...
Old 01-19-2019, 09:21 PM
Speculating here, but I wonder if the USB of the 11R is actually USB1(considering when it was introduced) and maybe that hammers the bus(remember that a FW400 interface can connect to a FW800 port but it only operates at FW400 speed(as will anything daisy-chained). Given the age of the 11R, I would look for an interfaced built for the speed of current computers and relegate the 11R to being the nifty guitar amp sim that it is
Old 01-21-2019, 08:46 AM
It’s definitely usb 2.0. I was an early adopter and had to shoot out some issue with digidesign at the time. They were clear to make sure that I wasn’t using a usb 1.1 cable as it was usb 2.0. I know that the mbox 2 was usb 1 and that an engineer at division told me they were going to make it 2496 but the usb 1 spec didn’t allow for it. Maybe getting a new Mac mini will leave me with so much extra cpu power I just don’t care lol. Have you seen the Geekbench scores on the 6 core i7? It’s nuts.
Real CPU Usage vs. Pro Tools System Usage Window tbonesteak4dinner Pro Tools 11 19 02-21-2019 08:04 PM
Midi switch or USB switch to punch in Pro Tools shamanrock Pro Tools 11 9 08-25-2017 08:56 PM
External talkback mic/switch/cuelight switch Pete Gates Post - Surround - Video 3 03-16-2011 01:53 AM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Switch Mac Mbox to Windows - and then switch back bluesigns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-07-2004 09:50 AM
