Does ELASTIC AUDIO always leave artifacts on every warp marker
Is it a virtual guaranty of artifacts with E,A .
I cannot seem to do anything with out making it worse for the best effort I give. I get artifacts get turning on E,A with no movement of warp markers. For the life of me I cant understand why I would want to use E,A if Im getting this much digital mess. COULD SOMEBODY PLEASE SCHOOL ME ON THIS I THINK I NEED IT |
Re: Does ELASTIC AUDIO always leave artifacts on every warp marker
What algorithm are you using? Some of the algorithms have limited settings that you can adjust a bit. I haven't had issues with just turning elastic audio on, but my audio files may be different from the ones that you are trying to elasticize.
It's the analyses markers that are causing the problem. Reduce the analyses sensitivity or manually remove the unnecessary analyses markers.
Buttdialed by me & Tapatalk
Here's what works for me. I cut the clip(formerly "Region")I want to edit, and copy to another audio track(right above or below the one I am working on), OR I duplicate the playlist and(very important step) cut the duplicate(anywhere) and then consolidate it(which creates a new and separate clip). Either way allows me to work on a clip WITHOUT messing with the original audio(nice to have that available, just in case....). Now I do the EA edits on the duplicate(or the separate track, which is way handy for working on small areas). Once I get things moved and aligned, instead of rendering it, I will bus it back to the original track(record to a new track if you used duplicate playlist). By doing it this way, its seems to impart artifacts less often, and you can revert and start over(and never screw up the original audio).
Thank you.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Elastic Audio and Warp Markers removal | stevegalante | Pro Tools TDM Systems (Mac) | 1 | 09-15-2011 01:54 AM |
Elastic Audio caveats. artifacts. | sweetness | Pro Tools TDM Systems (Mac) | 10 | 11-29-2009 01:43 PM |
Artifacts with Elastic Audio? | BreenMachine | Tips & Tricks | 5 | 09-20-2009 02:29 PM |
> Elastic Audio - Artifacts | Howardk | Pro Tools TDM Systems (Mac) | 11 | 03-16-2009 10:16 AM |
Can't WARP in elastic audio? | sureno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-29-2008 02:24 PM |
