Old 06-13-2011, 08:32 AM
Wayne_brady Wayne_brady is offline
Default Yet ANOTHER Mbox 3 Mini "Unable to Locate Hardware"
OK I'm running out of ideas here. I have searched through the forum and read lots of threads (most are either Mbox Pro or windows related) on the whole "Unable to locate hardware" issue. I have been using my Mbox Mini on my iMac i3 for almost 2 months now and so far it has worked great. Now all of a sudden it cannot locate the hardware. I have uninstalled/reinstalled PT LE 8.0.4, downloaded the new drivers...still nothing.
Last night I tried reinstalling PT again, and upon restart I plugged the Mbox hardware in like the instructions say. Then when the computer powered all the way up to desktop, the LEDs were flickering, flashing different colors and going crazy! Then normal blue light on, but still no hardware connection. I can even select the Mbox Mini in my sound preferences, but as soon as I close the dialog box, it goes back to internal speakers! I'm going to call Tech support tonight but figured maybe someone has an idea? Kind of wishing I would have gone with the Apogee Duet now
Old 06-13-2011, 08:42 AM
Talisker Talisker is offline
Default Re: Yet ANOTHER Mbox 3 Mini "Unable to Locate Hardware"
maybe, the extra driver is the problem, it belongs to PT 9, so right now, you've got two different drivers installed for the same device, that might be reason enough for it to go bananas.
Try to erase that extra driver, also get the latest PT update and see, what happens. good luck
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 06-13-2011, 08:44 AM
Oh, and are you running anything else in the background ? PT doesn't recognize hardware, which is captured by another application.
Old 06-13-2011, 09:14 AM
Ok thanks, I am going to try removing the new driver that I downloaded. Should I do another complete uninstall/reinstall as well you think? When I installed the first time, it worked fine straight out of the box, no updates or anything. Also, when is the EXACT time to plug in the hardware? The .pdf online says when you restart, after installing the software...but does that mean after the computer powers off or on the initial gray apple screen you first see when powering up?
Oh and I wasn't running anything in the background either.
Old 06-13-2011, 09:26 AM
well, to start with, remove the extra driver, reboot with the Mbox plugged in, and see what happens. If that doesn't do the trick, do a reinstall according to avid directions.
Old 06-13-2011, 10:10 AM
OK I will try this when I get home...but what worries me is that all of this started happening before I even downloaded the new drivers. I literally just woke up my computer and it wasn't working anymore, no updates or anything...
Old 06-13-2011, 10:17 AM
Park Seward's Avatar
Park Seward Park Seward is offline
If you select Digi hardware in sound prefs, then PT cannot use it.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-13-2011, 10:59 AM
It's not selected. Even if I try to select it, it just always goes back to internal speakers. When it was working, my internals were disabled.
So when I did the reinstall of PT, since I didn't remove the new drivers from my hard drive, was it trying to use both when I connected the hardware? The clean reinstall didn't remove all digidesign files?
Old 06-13-2011, 11:16 AM
maybe, it is also time for you to do some system service on your computer, boot with the shift key pressed, so it repairs permissions and all that other business, that you should do on a regular basis.
Old 06-14-2011, 08:21 AM
So I did all of this, and still nothing. I am so pissed that I bought this piece of crap over the apogee!! And I probably won't get my money back since I "opened" it. The sound quality is EXACTLY the same as the Digi branded Mbox, not any better like the people at Avid claim.
Thanks for your help Talisker/Park Seward, but I am dumping this thing, buying a Duet 2 and sticking with Logic.
PT10/Mbox Mini "Unable to locate hardware..." portrhombus Windows 3 12-21-2012 07:47 AM
"Unable to locate digidesign hardware" Mbox (original) ProTools LE 7.4.2 Mac OS X sharpd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 04-27-2012 12:11 AM
Mbox Mini 3 - "Unable to locate hardware" Platy Windows 0 02-06-2012 08:16 AM
Upgraded from 8LE to 9. "Unable to locate hardware" issue persists if no Mbox. Small Alien Windows 6 09-26-2011 02:18 PM
"unable to locate digidesign hardware" (mbox) what do i do monstaro General Discussion 0 01-23-2011 01:56 AM
