Audio Midi Setup issue..PT8 or OS10.5.5 problem?
Hi. This is only sort of a ProTools question, but I figure someone out there might have the answer....
I've had my Tascam DM-24 digital mixer connected to ProTools via MAudio Midi/USB Uno interface for use as a control surface for a few years now with no problem. I've recently upgraded my system to PT8 (HD Accel..PPC g5) and Mac OS 10.5.5 Now all of a sudden Audio Midi Setup won't save my settings for this simple task, or any other settings for that matter. If I hit New Config...it returns to the default. If I quit and reopen, it returns to the default. Same on shut down. So, now, every time I reboot I have to run AMS, reconfigure it for the DM-24 and leave it running in the background in order for Pro Tools to see the DM24 as a control surface. Anyone experiencing this problem? Is there a fix? Is there a better way to connect the DM24 to ProTools which doesn't require using AMS? (this is the only way presented in the manual) I don't use MIDI every really except for this purpose, so please forgive me if the question is stupid or the answer obvious :) I may revert to 10.5.4 to see if this fixes the problem. Thanks much |
Re: Audio Midi Setup issue..PT8 or OS10.5.5 problem?
Try this:
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'. Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'. Empty the trash and restart, then see if everything is working. |
Digi- Thanks for the quick reply. Tried your fix...no dice.
2 things: 1) I misstated my OS...I'm running 10.5.6 on this system 2) I think this is a Mac OS Bug...as a few friends also running this OS have the same problem and my 10.5.5 rig works fine. I'm sending Apple a bug report, but if you guys have any pull over there and can get on them as well it'd be helpful :) Thanks much |
Audio Midi Setup issue with TD-15(V-Drum module) | Armando | MIDI | 1 | 03-27-2013 07:57 AM |
Audio Midi Setup, Multichannel Audio Problem | soundeditor76 | Pro Tools 10 | 0 | 04-13-2012 04:49 PM |
Audio/Midi setup issue | BaileyBass | Pro Tools 9 | 2 | 02-11-2011 05:08 AM |
Audio Midi Setup problem | netz11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-25-2007 08:22 AM |
Audio Midi Setup Problem | Muzoid | MIDI | 1 | 09-26-2005 11:26 AM |
