Old 06-19-2005, 07:13 PM
elv1s1sal1ve elv1s1sal1ve is offline
Default Kontakt 2 not appearing as plug in
Kontakt 2 is not showing up as a plug in when I go to select instruments in the RTAS insert section of my aux track. I selected all plug in types during the Kontakt 2 installation process. Any advice?
Gateway 7510GX, AMD Athlon 64 3700+ 2.39 GHz, Windows XP Pro, PTLE 7.3.1.123, MBox, 1 GB RAM, external Seagate 150 GB HD
Old 06-19-2005, 07:15 PM
spkguitar's Avatar
Default Re: Kontakt 2 not appearing as plug in
Are you using it on a stereo track? Kontakt is stereo only and will not show up in a mono track's list.
Old 06-20-2005, 04:28 PM
No...it still does not appear, even when I select a stereo track. Does it have anything to do with Kontakt 2's filepath?
Old 06-20-2005, 06:14 PM
spkguitar's Avatar
Not sure about the program itself, but most certainly the Kontakt2.dpm file should be located in C:\Program Files\Common Files\Digidesign\DAE\Plug-Ins
The install selects that location by default, but if you changed it for some reason, that would be the problem.
Old 06-20-2005, 07:11 PM
Yeah, the dpm file is in that path...is there possibly something that I do not have setup correctly in PT?
Old 06-20-2005, 07:51 PM
spkguitar's Avatar
I thought from your other thread that you had this working.
There are no special settings.
On a Stereo Aux track, click the channel's insert and select Multi-Channel Plug-In > Instrument > Kontakt2.
If Kontakt is not on the instrument list, then there is something wrong with your Kontakt install and I would contact (no pun intended) Native Instruments about it.
Plug Ins Not Appearing in PT 7.4 lionelcollins 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-03-2008 03:42 PM
png icons appearing in plug in folder georgiateleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-19-2008 10:27 AM
RTAS plug ins not appearing in Pro Tools noiseboy55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2007 09:21 AM
Plug-In Not Appearing on List FINKSTONE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-07-2007 09:33 AM
multiple outps for Kontakt not appearing in PT aux dj_grimmace Pro Tools TDM Systems (Mac) 15 08-28-2005 12:19 PM
