Old 02-12-2020, 07:25 AM
dg27's Avatar
dg27 dg27 is offline
Default Re: Moving from 12.8.3 to 2019.12
Nothing to worry about. The older .ptf session format opens just fine in PT10 and later, and .ptx format introduced in 10.0.0 is still current. Going for a newer version is not a problem.
Thanks--this is good to hear. Would hate to think there'd be a problem with earlier session.
Originally Posted by kw88keys View Post
I did the same as you - updated to W10 and from 12.4 to 2019.12.
The only glitch was Windows 10 populated my bios with a floppy drive.
That caused a 6 second delay in record and playback-after-record. Once I went into bios and removed (not disabled) the floppy all went well.
Thanks for pointing this out!
Old 02-12-2020, 06:16 PM
dg27's Avatar
Originally Posted by EGS View Post
I suggest NOT installing those, but rather be sure to install the latest/greatest versions of all plugs. Typically, just go to each company's site and DL the latest versions. The latest AVID plugs are also available to DL. A few months ago I updated Win 7 to 10, got the current PTools, and all current plug versions ---> works!!!
Thanks SO MUCH for suggesting this. I've started going to sites and I'm seeing that most of mine are outdated.
Old 02-13-2020, 04:23 AM
EGS's Avatar
EGS EGS is offline
Outdated plugs can cause problems ...
Click for audio/video demo
Click for resume
Old 02-13-2020, 12:29 PM
dg27's Avatar
One more question has come up: I'm currently using an MBox 3 interface.
The Avid instructions say to install the interface drivers before installing PT.
For 2019.12, do I use the HD Driver 2019.12 even though I have "regular" PT?
On the Avid page for MBox drivers, the information for the latest driver says it only supports up to 12.5, which is weird because I'm currently on 12.8.3.
http://avid.force.com/pkb/articles/d...d/Mbox-Drivers
Hoping someone can weigh in on this.
Thanks.
Old 02-13-2020, 12:33 PM
Supported and working are two different things. Sure it has been tested for High Sierra the latest and you can run 2019.12 on HS as a supported configuration. Anything beyond that and you are on your own.
HD driver is for HD hardware.
Old 02-13-2020, 12:34 PM
It actually means you can install PT first but you should not expect to see your interface show up until you have installed proper drivers
Old 02-13-2020, 12:47 PM
dg27's Avatar
Thanks for the replies. I'm having no luck determining whether the most recent MBox 3 driver is compatible with 2019.12.
Old 02-13-2020, 01:09 PM
Hardware compatibility goes against OS.
2019.12 is compatible with High Sierra and mBox3 is compatible with High Sierra so yes, if you use High Sierra your combo is supported.
OS later than High Sierra is not supported but may very well work. You are on your own though.
Old 02-13-2020, 01:36 PM
dg27's Avatar
JFreak,
Thanks for your reply.
As I said at the start of the string, I'm moving form Windows 7 Pro to Windows 10 Pro, then from 12.8.2 to 2019.12.
(I'm not on a Mac.)
If it's strictly tied to the OS, the latest MBox driver should be fine based on this:
1.1.10 Dec 16, 2014
Fixed: The "Updates" button in MBox control panel referred to outdated page
Supports Windows 7, 8, 8.1 & 1.1.10 Dec 16, 2014
Supports Windows 7, 8, 8.1 & Windows 10
Supports Pro Tools 11.0.x - 12.5
Old 02-13-2020, 01:41 PM
Sorry, got confused as this topic is on another thread also
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
2019 iMac vs 2019 Mac Pro Peterjk Pro Tools HDX & HD Native Systems (Mac) 7 01-14-2020 12:23 AM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
