Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Closed Thread
Old 09-03-2020, 04:06 PM
goshalev goshalev is offline
Default Problem with maximum Voices/Tracks in Pro Tools 2020.9
Pro Tools (not Ultimate)
Voices reduced from 64 stereo to 32 stereo tracks in 2020.9.
In 2020.5 in System Usage window shows Voices /128.
in 2020.9 shows /64.
96 kHz project!
I can not open 2020.5 projects
ADMIN EDIT: http://duc.avid.com/showthread.php?t=411759
Last edited by DigiTechSupt; 09-04-2020 at 04:23 PM. Reason: Added link to Tech Alert
Old 09-03-2020, 04:24 PM
Akiz Akiz is offline
Default Re: 2020.9!
In what sample rate those projects are? Is it other than 44.1/48khz?
This is where voices will drop in half.
ProTools 2020.9 Ultimate here and voices are still 384 @44.1/48Khz, nothing has changed.
Cheers!
In 2020.5 in System Usage window shows Voices 128/128.
in 2020.9 shows 64/64.
Mac Pro 6.1 "Late 2013", 12 Core 2.7 Ghz, 32Gb Ram, 1Tb SSD, MacOs 10.14.6 "Mojave", Apogee Ensemble Thunderbolt, Softube Console 1,
Avid Artist Mix, Pro Tools Ultimate 2021.7.
Old 09-03-2020, 04:43 PM
Default Re: 2020.9!
I have Pro Tools NOT Ultimate.
Once again
In Pro Tools 2020.5 System Usage/Resources/Voices window shows max 128 at 96 kHz or 256 at 44.1 kHz.
Now in Pro Tools 2020.9 System Usage/Resources/Voices window shows max 64 at 96 kHz or 128 at 44.1 kHz.
Where can I buy voice Pack for Pro Tools NOT Ultimate to use PT 2020.9?
Old 09-03-2020, 04:58 PM
Default Re: 2020.9!
Create an empty project @ 44.1 or 48Khz.
Can you check on Setup->Playback Engine window, that the audio interface is the one previously used, for example mine is Ensemble Thunderbolt. Is it other than that, maybe "Soundflower 2ch"? If so select the correct audio interface from the drop down menu.
How many Max voices are shown there? Does it say 256 now?
p.s. Are you on Mac or Windows?
Cheers!
Once again
Old 09-03-2020, 05:46 PM
Default Re: 2020.9!
Cheers!
Pro Tools NOT Ultimate never shows Voices count in Playback Engine window.
I always use My RME only card.
I am on Mac.
Old 09-04-2020, 12:38 AM
Wolfgang Eller Wolfgang Eller is offline
Default Re: 2020.9!
You're right.
But as far as I can see PT is not making a different voice count if it is a mono or stereo track anymore.
www.srs-mastering.de
Mac Pro 6.1-8core, OS 12.6, PT2023, HDX2, Sonnet Echo Express III-R, Madi Interface.
Old 09-04-2020, 12:42 AM
Default Re: 2020.9!
Seems a bit strange to me, if they had reduced the voice count in Pro Tools 2020.9, a lot of people would have voiced their complaints by now.
You should hit the Avid support, to get a clue of what is going on.
I just try to help with some basic troubleshooting, i don't have Pro Tools "Standard", to verify the voice count, maybe someone else can chime in and shed some light on the case. Hope you'll short it out soon though.
Cheers!
I am on Mac.
Old 09-04-2020, 12:54 AM
Emi's Avatar
Emi Emi is offline
Default Re: Voices reduced from 64 stereo to 32 stereo tracks in 2020.9
And they did,
Now you can´t open more than 64 stereo tracks / 48khz
On 2020.5 you could open 128 mono or stereo tracks...
Avid, your updates are downgrades in reality.
OMG, I really can´t believe a company does this to their customer.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 09-04-2020, 12:58 AM
Emi's Avatar
Emi Emi is offline
Default Re: 2020.9!
I´m back to 2020.5 and freeze there
Stereo tracks are reduced to max of 64 at 48Khz
This is a downgrade in reality
Old 09-04-2020, 01:13 AM
WOW!!!
More users need to confirm this.
If that is NOT a mistake by them, then it is a massive slap in the face for standard Pro Tools users...
Epic failure Avid!
Originally Posted by Emi View Post
And they did,
Closed Thread
maximum voices at 96k??? drvibb Pro Tools 9 2 11-04-2010 10:43 PM
maximum # of voices with HD2 Accel/core ....best u jmallen Pro Tools TDM Systems (Win) 1 05-29-2006 08:35 PM
