Re: Minor Bug/Gripe - "Bounce to" location
Sorry, but I'm not sure everyone is taking the time to understand the OP's post; the issue is not changing the *session* folder's name or location (this is obviously a very bad idea), but in bouncing to an external drive or external folder. If you're in a photo editor or even in Pro Tools and export a file to an external folder or drive, then remove that drive, then do another export later, the program does NOT force a close and restart - you are simply presented with the option to export somewhere else. The bounce dialog should be no different as you are creating a new file external to the session (assuming it won't be used in the session); if the last external location of a bounce is no longer available you should be able to simply select a new one - in Pro Tools you cannot do this; instead an error is thrown and you're forced to close and reopen. This is certainly lousy UI design if not a bug. Anyway, it is a minor gripe, but it has driven me bats on several occasions as, apparently, it has others. best, rich
Scott Gatteño Last edited by originalscottyg; 05-29-2018 at 02:14 PM. Reason: addtl info |
Have you tried renaming folders using the Workspace browser? In doing so, one tells ProTools that a change in file structure has occurred, instead of the Finder (which PT has no way of knowing until a session is read again upon reopening it.)
That said, I’m with those who suggest that PT should simply ask for a new bounce destination, instead of throwing up an error alert.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . Last edited by Andre Knecht; 05-29-2018 at 10:43 PM. |
Scott Gatteño |
I went ahead and created an ideascale topic for this. Please vote if this annoys you as well. Thanks!!
https://protools.ideascale.com/a/dtd...a-tab-comments
Scott Gatteño |
Exporting Midi - "Location Reference" Option Greyed Out...sometimes... | Sparky1 | macOS | 4 | 07-21-2022 01:53 AM |
"Bounce To Disk" Track is "Lower in Volume" | LSNY | Pro Tools 12 | 18 | 06-05-2017 08:45 PM |
"Select a Location" when activating Pro Tools 11 | JNS9300 | Licensing & Accounts | 1 | 03-16-2017 04:59 PM |
Memory Location "Selections" Not Stopping After Playback | Cgbravo | macOS | 3 | 07-16-2014 09:28 PM |
Strike..Can not find "set content location application" | moniz.m | Virtual Instruments | 1 | 01-13-2013 05:17 PM |
