Old 10-29-2003, 12:37 AM
Soulenesia Soulenesia is offline
Default PTLE Filing - Organization tips
I'm about to start mixing my first project with my 002, LE, and G4 Powerbook. My question is - What's the most efficient way to file my songs? Do I mix in the original PTfile, or open a new file for my mix and import files from original tracking? And when I'm done mixing, how do a archive my album with out all the unused takes? I know these may seem like stupid questions. I know the different options but I'd like to hear what works best for you all out there. Peace.
Old 10-29-2003, 03:23 AM
marty martin marty martin is offline
Default Re: PTLE Filing - Organization tips
Personally I would use the same session file to track and mix, I'm not really sure why you would want to do it any other way.
As for general organisation I would consider backups to be the most important thing, and the "Save Session Copy In" command.
I would usually have my regular session, a backup on my other HD, and a hard backup on cd or dvd. I always have to learn the hard way.
As for archiving, just use the "compact selected" command under the Audio files menu in the Edit window.
Everyone likes to skin their cats their own way though.
Studio: Mac Pro Trash Can 2.7 Ghz, 32Gb RAM, Sonett xMac Pro Server, HDX 12.4, S6 M10 24 Fader, Rednet 5,1 and 4
Live: MBP 15" 2.5Ghz i7 16Gb RAM, Avid S3L, Venue 4.5.1, OS10.11.1 + PT12, UAD Apollo 8
Old 10-29-2003, 07:36 AM
orage orage is offline
If you do mix in a separate session than the one you tracked everything in, make sure you create the mixing session using Save Session Copy As function so the session has it's own folder, complete with audio and fade files folder.
If you simply create another session for mixdown and save it within the same folder as the tracking session, both sessions will reference the same fades and audio files. This can be a problem as one session will rewrite/reallocate all of the fades in the folder, so if you open up the other session, it will ask you to find all of the fades that used to be in the designated folder...you can simply tell PT to ignore finding all the fades and it will then proceed to recalculate every fade file, which, depending on how many fades were in the session, can take quite a while.
For archiving, use compact selected to shrink the session size. Personally, I try and archive everything from the session, even if it wasn't used and have found that DVD-R's are usually large enough to handle the job.
Paul Peterson
Sound Director
The Old Globe
San Diego, CA
Filing system ? Bob Hoffnar Avid Scorch (iOS) Forum 11 06-06-2012 05:18 AM
Filing lscroggin VENUE Live Sound Systems 2 08-20-2011 05:38 PM
noooob question to do with filing... ron player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-21-2007 06:28 AM
Page filing for 1Gb... scottedog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-26-2004 08:59 AM
From VHS to PTLE tips etc help??? graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-22-2004 12:26 PM
