Old 10-03-2001, 08:59 AM
Samhein Samhein is offline
Default C24 Monitor section dead
We just hooked up the C24. Everything seems to work fine, (moving faders, level meters on both the tracks as well as the monitor section LEDs.
The only thing is, we can't seem to get any sound coming out of the C24 monitor section, although the monitor lights are all moving to the demo file on the C24.
We've swapped C24 cable, but to no avail. Nothing is soloed or muted. Both the main monitor and sub-monitor knobs are up all the way. All the ProTools and external input sources are selected.
Did a system reset as well. Still nothing. The system is connected to the new PowerMac G4/733.
Any tips or checks that can be done to verify if this is not a faulty unit?
Old 10-03-2001, 08:22 PM
darla darla is offline
Default Re: C24 Monitor section dead
[QUOTE]Originally posted by Samhein:
[QB]We just hooked up the C24. Everything seems to work fine, (moving faders, level meters on both the tracks as well as the monitor section LEDs.
Is the PT Sources Button set to (L/R) (PT1&2)?
Monitor mode set to Stereo?
Harness plugged into the correct D-sub output & using pair 1 & 2 from that harness to your amp?
Lastly, can you monitor off the Aux Outs to your amp? Be sure to press the "Monitor to Aux" button. Hope this is some help.
Old 10-04-2001, 02:43 AM
ianmiller ianmiller is offline
Stick a pair of headphones in and check that output to see if there is anything there as well. Make sure (if you have a master fader channel in the PT song) that it is up and that the master volume on the C24 is up (OK - pretty obvious but trying to think what it could be) - Good luck
Old 10-05-2001, 03:10 AM
Thanks folks.
Did all that before sending the SOS here. I think the unit's monitoring section has died. [img]images/icons/rolleyes.gif[/img]
Monitor Section Hanswurstlsepp Avid S4/S6 36 06-06-2014 02:52 PM
C|24 Analog Section Dead kyguy ICON & C|24 2 02-21-2011 04:06 PM
C|24 controlroom/monitor section dead 24BitMusic Pro Tools TDM Systems (Mac) 4 01-01-2011 02:06 AM
Dead Monitor section and Faders! Chris Coleman ICON & C|24 6 11-05-2002 06:23 PM
PC monitor section nworb ecnal ProControl, Control|24, Command|8 0 03-15-2002 11:33 AM
