Old 12-22-2023, 08:34 AM
musiclee musiclee is offline
Default Best Time Compression Plug-In ??
So I do a ton of narration editing and producing
In many different languages
And many times I have to speed up narration to match length of audio
As some languages (ie Spanish) are typically 20% longer
I also need to speed up, slow down music as well.
What is the BEST time compression/expansion VST?
I have tried those built into protools
And they are lackluster at best.
I can go about 5%, after that I can hear artifacts and skipping audio.
What’s crazy is I DJ as well. And the time compression algorithms there are way better , using Serato DJ , or Alggoridim DJay
FYI. I also own RX Advanced and they don’t impress me
Thanks everyone for any advise.
Old 12-22-2023, 08:40 AM
Default Re: Best Time Compression Plug-In ??
Serato Pitch N Time Pro with the Voice algorithm is fantastic and can be assigned to the TCE Trimmer tool. It's not cheap though.
If I didn't have that, I would use the Avid TC/E (Legacy) setting for the TCE Trimmer tool, instead of the Avid Time Shift setting. Time Shift is absolutely useless IMO, but the Avid TC/E setting works quite well for small dialog edits. But I still prefer Pitch N Time Pro over any of those.
Scott Gatteño
Old 12-22-2023, 09:49 AM
thanks. , i have mine defaulting to Avid Time Shift, so i guess only option right now is to try the other one, the Avid TC/E,
thx, anyone else?
Old 12-22-2023, 10:39 AM
Just tried the Avid TC/E algorithm
And it’s night and day from the default Time Shift
Can’t afford Serato PnT so I’ll stick to this.
Thanks Scotty
And why would Avid use this Time Shift as its default when they have a much better option. ?
It sounds awful this Time Shift one.
Old 12-22-2023, 10:50 AM
noiseboyuk noiseboyuk is offline
This thread is worth a look - https://duc.avid.com/showthread.php?t=425647
I use Elastique Pro AAX TC/E. Same algorithm as used in Elastic Audio, but available as a TC/E option. Way better than any of the Avid bundled ones and a fraction of the price of Pitch n Time.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 12-22-2023, 11:55 AM
i accidentally posted this on another. Serato P-T thread but wanted to post here....sorry
"wait a minute.... i'm on 2022.12
seems that in 2023.3 they added. zplane's Elastic Pro AAAX, a $200 plugin, "alogithm". that supposed to top anything Avid had prior,
anyone use this one? scotty?
time to upgrade my protools to 2023.12, it's free, it's a new TC/E tool, which i really need
i'll believe it when i hear it.
Old 12-22-2023, 11:57 AM
thin ice thin ice is offline
If you want a cheap option that sounds good, try the Waves Sound Shifter.
I agree that Serato Pitch n Time is best, but the cost is crazy and updates are slow. X-Form is good quality, but is takes a long time to process.
Mac Mini M1 16 GB
OS 12.7.4
PT 2024.3.1
Old 12-22-2023, 12:02 PM
I'm slightly confused by this post, but default Pro Tools Elastique is only used in Elastic Audio, not TC/E. TC/E is still a separate product.
Guy Rowland
Old 12-22-2023, 12:31 PM
oh, not sure, maybe that Elastique from zplane (now in 2023.3 and above) indeed is only in Elastique Audio, i would love it in TCE tool,
i know zplane sells 2 versions, the plugin, for over $300,
and the TCE only version, same algorithm, no UI, no pitch shift, for about 1/2 the cost...
i will install 2023.12 and verify!!
Old 12-22-2023, 06:37 PM
skylar_battles skylar_battles is offline
I just got the TC/E only version of élastiquePRO and will be using it. I'm hoping it will better for quick drum and bass edits when beat detective still leaves some slight time stretching to be necessary, so I don't have to engage elastic audio in those cases.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
exponential time compression plug in ronoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-31-2008 12:28 PM
Best Time Compression Expansion Plug? SHC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-13-2007 10:51 AM
Time Compression Plug ins - any suggestions? DEXTERITY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2006 03:39 PM
audio suite time compression plug-in Bill Sanders 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 05-22-2002 03:20 PM
Time compression Plug-in's Jerrold Launer Pro Tools TDM Systems (Mac) 2 12-04-1999 03:58 PM
