Old 08-15-2023, 01:22 PM
briaboy briaboy is offline
Default Quit error message?!
I receive this error message (attached) every time I quit PT, even though I have just saved the session and quit PT correctly.
iMac (2020: 3.8 GHz 8-Core Intel Core i7, 32GB), OSX 14.1 (Sonoma), Pro Tools 2024, UAD Apollo 8, UAD-2 Quad Satellite DSP Accelerator, 2 x Lacie Thunderbolt SSD (250GB), Seagate Backup Plus Drive (4TB).
Old 08-15-2023, 02:30 PM
Southsidemusic's Avatar
Default Re: Quit error message?!
Hey
For us it was a bad plugin and that plugin was Slate Digital EiosisEQ that kept is from quitti g PTU without having to force quit PT.
Wetook it out and all 3 of our PTU systems on Mac Pro’s 2019 works great now.
It can be a demo plugin or an old version of a plugin that keep disrupting so sadly you might need to go thru your plugin library to find the offender in the AAX folder.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 08-15-2023, 03:53 PM
I don't have to force quit though. I close the session, then quit Pro Tools, and it shuts down. After several seconds, the error message appears (i.e. well after PT has actually quit!).
Old 08-15-2023, 04:24 PM
The message is 100% reliably telling you something is failing. A slight delay in the notification system to post a message like this is normal.
As always suspect a plugin, (even if Chris was mentioning a different issue).
Standard stuff...
- Trash prefs.
- If you remove *every* .aaxplugin file from Pro Tools does this still happen?
- If it still happens does it still happen with only some sessions?
- Do the Pro Tools log files show anything different near their ends when this happens vs. not?
As with most issues, you should just jump in and do standard troubleshooting steps...
Message upgrading 7.0 - You must quit Pro tools... Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2005 02:50 PM
"unexpectadly quit" error message in PTLE 6.22 jpf99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-05-2005 01:34 PM
"Pro Tools unexpectedly quit" message pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-08-2004 06:40 AM
Message from Pt 6.1 on quit A Potential Bug... smlworld Pro Tools TDM Systems (Mac) 0 10-17-2003 02:06 PM
PT LE 6.1 Unexpectedly quit message geoffh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-06-2003 08:23 AM
