Old 06-06-2022, 08:03 AM
phill168 phill168 is offline
Default Pro Tools 5 some audio tracks not playing
I have some old sessions that were created on PT 3.4, the free version. I can open the old sessions on Pro Tools 5, but some tracks are not playing at all.
It's all very weird. The audio file is there, volume shows 00, and when I scrub the track, I can hear the audio, but when I try to play it, nothing. I have checked everything, solo and mute are off, output is 1/2, playback engine is Audiomedia III and there're no plugins.The strange thing is it only happens with a few tracks, the other tracks play fine.
I was wondering if anyone remembers this problem and if there's any fix. Is this a problem with the sessions being created on an earlier version?
Old 06-06-2022, 08:26 AM
Default Re: Pro Tools 5 some audio tracks not playing
I can't speak on this old a setup, but as a troubleshooting step, do a Save Session Copy(include audio files and enforce Mac/PC compatibility if its an option) and then try opening this copy.
Still no luck? Are the regions muted(grey'd out)?
Still no luck? Consolidate and export all the audio files and import to a new blank session.
One more option; If the audio is in SD II file format, export the audio as wave and import into a modern DAW(unless you have a reason that it needs to stay in PT5)
Old 06-06-2022, 10:04 PM
Originally Posted by albee1952 View Post
I can't speak on this old, but as a troubleshooting step, do a Save Session Copy(include audio files and enforce Mac/PC compatibility if its an option) and then try opening this copy.
Thanks for all the suggestions! I tried re saving the session but no luck. The tracks were still not playing. I think consolidating the files and importing them into a new session will work. But I'll probably do that as a last resort.
The problem only exists in old sessions done on PT3.4. I have a bunch of sessions that were done on PT5 and they all play ok. Will keep on trouble shooting.
Thanks again for the help.
Old 06-07-2022, 11:06 AM
Top Jimmy's Avatar
Are the track voices all assigned properly? If two tracks share the same voice and they both have regions in them at the same place in time, then you’ll only hear the higher track.
As I recall, PT Free only allowed 8 voices so that’s why I would suspect this.
James Cadwallader
Old 06-07-2022, 05:26 PM
It's definitely a problem with the voice assignments. I just checked the manual for PT 5.0.1 and on page 55, it shows an audio track voice selector in the i/o view next to the rec button, but there's no voice selector on my current PT 5 install. I'll try to find an update. Maybe it's a bug with 5.0.
Thanks for all the suggestions.
Old 06-08-2022, 01:43 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
On 5.* I sometimes had what may be a similar issue. What always worked was creating a new audio track and dragging the audio to the new track and deleting the old channel. Copying didn't seem to work. Worth a shot anyway
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
HTML code is On
some of my vocal audio tracks not playing back...help superdood Digidesign Hardware & Software 13 11-19-2021 08:31 AM
Audio tracks gone white and no audio playing from them puddle Pro Tools 12 12 11-02-2016 11:32 AM
PT 10 not playing audio on some tracks. help please [SOLVED] THE_NIK macOS 11 10-24-2014 04:52 AM
tracks not playing audio till plugs are reinserted Seeee Pro Tools TDM Systems (Mac) 0 01-18-2004 01:08 PM
Playing Absynth through PTLE. Only through Audio Tracks? Timothy72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-06-2002 04:25 PM
