Old 12-22-2016, 06:38 AM
Carl Lie Carl Lie is offline
Default Sierra Install Gone Bad - need help [solved]
Hey folks.
I tried to install Sierra and it crashes when I boot (constantly loops through a kernel panic). I want to be able to boot from my backup drive (proof that one always needs a backup) but I cant even boot in safe mode.
Is there a procedure that will allow me to select the backup disk to boot off of?
Thanks
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 12-22-2016, 06:42 AM
cut cut is offline
Default Re: Sierra Install Gone Bad - need help
Originally Posted by Carl Lie View Post
Hey folks.
Thanks
Carl
Hold down option key while powering up
Old 12-22-2016, 07:04 AM
Default Re: Solved- Sierra Install Gone Bad - need help
Thanks. I was able to boot with recovery tools - command R and am restoring from backup.
Thanks for your quick reply.
C
Should I install OS Sierra with v. 12.5.2? fchef25 Pro Tools 12 3 10-10-2016 05:05 PM
Air Creative install problems [solved] dr_daw Pro Tools 11 3 12-24-2014 01:52 PM
How do I install Air Creative Collection 11.1.0? [solved] JGlen Windows 4 12-26-2013 04:45 PM
bought heat how to install [solved] Filmusic Pro Tools TDM Systems (Win) 7 02-09-2013 07:43 AM
install loop and install failures Solved.....so far soybalm Windows 1 04-17-2012 08:40 PM
