input settings problem
I am having trouble with input settings. My 003 rack has 4 microphone inputs, but only Mic 1 and Mic 2 show up as available input settings in the Mix window "interface" tab. And the same under the pull-down menu Setup--I/O setup-- Input. I want to record using 4 microphones, each onto a different track.
What am I doing wrong? appreciate any and all suggestions. |
Re: input settings problem
In the I/O settings, Input and Output tab, click Default.
Aaron Mulqueen - 001 HD Native |
You might want to delete the current routings before hitting default.
This is a long-standing I/O issue. What happens is that when you open sessions from someone else, you also bring in their I/O setup. When you quit the session and next create a new session, that I/O setup will continue if you leave the I/O settings as "Last Used" in the new session dialog. Here's what to do. Setup the I/O routings and busses the way you like it and even customize the names if you like and save this I/O setup. Then, when you create a new session, select this I/O setup from the pulldown menu. This way, you'll always be sure to have your I/O setup.
Thanks for the quick reply. I did this, and re-populated the input settings with the Default settings. But now I have no microphone inputs at all, instead of the Mic 1 and Mic 2 I had before. How do I get inputs for all 4 mic inputs to show up? Thanks again!!!!
I also tried "import settings" in the I/O setup window, but it only gave me choices for "Eleven Rack" or "Control24 LE" settings, neither of which has mic settings. Now I can't even retrieve the 2-mic settings, much less 4 mics. Argh!
Thanks,
Based on your suggestion and some creative fiddling I was able to get it going! Thank you very much for taking the time to respond! Best |
HD OMNI input settings i/o | hydraonstimpac | Pro Tools HDX & HD Native Systems (Mac) | 2 | 03-31-2013 06:46 PM |
I/O input settings not defaulting...? | Jsalam112 | Pro Tools TDM Systems (Mac) | 0 | 10-30-2005 07:54 AM |
Default Input settings | Ludicrous Speed | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-01-2004 01:25 AM |
Input level settings questions | splitsurround | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-18-2001 01:21 PM |
Pod 2.0 unit best input settings | KamaSutra77 | General Discussion | 0 | 04-08-2001 07:52 PM |
