Old 07-03-2011, 01:37 PM
Devastationdynasty Devastationdynasty is offline
Default M-Powered Protools 8 issue Windows 7
So I am giving this a try again. Hopefully this time will be better. So I have installed Protools 8.0.5. But I still don't have any of the virtual instrument plugins. All I really is the drum machine. This has been nothing but a headache from the start, but I am trying to do what I can. I don't want to spend extra money on this if I don't have to. Is there any way to get the Creative Toolkit for my 8.0.5 for Windows 7 64 bit? Thank you in advance.
Old 07-06-2011, 12:14 PM
markolone markolone is offline
Default Re: M-Powered Protools 8 issue Windows 7
for me never work protools on windows seven 64 bit...
when i setting low buffer for use low latency....only click or noise...
i try ...
who use in this forum with a laptop with norman processor i5...ecc
protools and work really?
all my friend, have to install windows vista or xp...is you want use protools...
i don't like to spend more money with protools..and i think to buy my protools...and use other software who really work.
the support is NOTHING from avid...
HP HP Pavilion dv6 Notebook PC
Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz
4GB DDR3 SO-DIMM
Memoria Totale : 4GB DDR3 SO-DIMM
Velocità Bus di Memoria : 2x 532MHz (1GHz)
Video : NVIDIA GeForce G105M (16 SM4.1 1.23GHz, 512MB DDR3 128-bit, PCIe 2.00 x16)
Seagate ST9320423AS (320GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Sistema Windows : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Conformità della piattaforma : x64
maudio 410, maudio solo
windows vista,quad core intel
Old 07-06-2011, 12:20 PM
browniespeaks browniespeaks is offline
I do every day. Lenovo T510 and mbox 3 mini
desktop at home is a AMD Athalon X2 4800+
Project space has i3, i5 and AMD based systems ALL running windows 7
there are plenty of guides on system optimization here. follow one of them and you may have some success. in lew of that post a sandra report and ask a question that has an answer in the form of instructions.
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 07-06-2011, 12:24 PM
"Sistema Windows : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)"
Are you running home premium or home basic? the latter is unsupported and may be the cause for some of your problems.
Clifford Brown III
www.brownaudio.com
Old 07-06-2011, 01:08 PM
yes i use home premium , this is the realy problem?
what version i need?
4GB DDR3 SO-DIMM
Old 07-06-2011, 08:10 PM
home premium is ok. So thats not it. Markolone start a thread with sandra report and a specific second by second account of your problems. The OP should do the same here.
Clifford Brown III
www.brownaudio.com
Old 07-08-2011, 02:10 PM
thank tommorow i make a report with sandra, and write my problem.
the problem i have is with latency, when i use buffer low of 256....nothing work.but first i post my profile with sandra.
thank
4GB DDR3 SO-DIMM
Old 07-09-2011, 02:47 PM
kellyestabrook kellyestabrook is offline
I have Pro Tools M-Powered version 8.0.3 and the install DVD is for windows xp or vista....and i have windows 7...is there any way to download something so that i can make it compatable? or should i just buy protools 9? would that just make everything easier? sorry i know this is a little off topic but i dont know where else to turn! i can never get through to anyone on the help line!
Old 08-16-2011, 10:55 AM
hooksound hooksound is offline
According to AVID, Pro Tools M-Powered 8 is supported on Windows 7 from 8.0.4 and higher. But reality has obstructed things before.
Old 08-17-2011, 01:36 AM
SSE4.2 SSE4.2 is offline
I got Pro Tools M-Powered version 8.0.3 and installed it on W7 and then installed 8.0.4 update. Ok so far, but I’m not a power user, just a weekend hobby jockey.
ProTools M-Powered 7 on windows 7 Lkj Pro Tools M-Powered (Win) 0 01-10-2013 03:13 AM
Protools 10 (Windows 7 64bit) Launch Issue abrstudios Windows 20 11-06-2011 09:33 AM
Here's ProTools M-powered 8.04 for Windows mlange Pro Tools M-Powered (Win) 17 07-20-2010 09:59 PM
protools 8 windows 7 VST wrapper issue awthentik83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2010 12:59 PM
Issue installing protools LE8 on windows XP the01habitat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-18-2009 11:30 AM
