Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-08-2001, 07:52 PM
KamaSutra77 KamaSutra77 is offline
Default Pod 2.0 unit best input settings
Hello folks,
I've been struggling with my standard Pod preamp ( with the 2.0 upgrade installed) to get the best sound input. What input gain setting works best for you all out there using the pod? I had assumed -10 but not sure if its working right, I seem to need more gain which introduced lots of noise. But then again, I'm finding that pushing the levels to high is intrdroducing artifacts and digital distrotion well befroe the signal says it's clipped in the meter. Is it best then to stay in the green for digital recording, even avoiding yellow no to mention red peaks?
2. The amp/direct switch whats your take what works best? I'm getting to the point where it seems the best sounds come forma cabinet miked up and fed in as a mic signal, the pod acting as a fancy preamp fuzzbox, which is too bad Id like to be able to work into the wee hours tracking cool riffs.
Huh?
HD OMNI input settings i/o hydraonstimpac Pro Tools HDX & HD Native Systems (Mac) 2 03-31-2013 06:46 PM
input settings problem rick schaulyoder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-03-2011 10:20 PM
I/O input settings not defaulting...? Jsalam112 Pro Tools TDM Systems (Mac) 0 10-30-2005 07:54 AM
MBOX Input gain settings. lbanks75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-16-2005 01:25 PM
Default Input settings Ludicrous Speed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-01-2004 01:25 AM
